Anyone ever used plasti-dip?
sl8rxlr8r
Buy the ticket, take the ride.
Would like to dip the spring on the exterior of my front forks on the CB350, and the rear shock springs too..... Anyone ever used it? Good, bad, indifferent? Does it hold up well on springs?
Says "flexile -won't tear or crack"..... we'll see...
http://www.plasti-coat.com/dipcoat.htm
Might work, so long as they don't get too cold.
Brafasco sells little tins of this sort of thing in different colors. I was thinking of picking up a tin of black, to dip the end of my sidestand in so I could protect the powdercoat finish below. Figure peel it off and re-dip once a year or so to keep it in good shape.
my brother and I made a tribute to Richard Petty with the "Plasti-dip Richard Petty". It seemed to work ok for this.
:D
Actually I've used it to coat tools too and it works fr that too.
Then you find out it has 10,000% mercury & lead paint levels over any North American safety standard, after an eyeball grows on right hand!!...
don't know about springs but i have used it for diffrent stuff, works good, once you open ti it doesn't last forever,must be kept airtight, nasty chemical ocour, but tough stuff. spotless surface prep with some roughness, like sanding/blasting = good success.
So ... I went to http://www.plasti-coat.com/dipcoat.htm
I emailed them to ask about their product.
According to them "The true plastisol materials that we use require processing ovens and are
not readily available in small quantities."
Their recommendation was to use air-dry stuff called "Plasti-dip".
I'll be ordering some for springs. I'll let you know how it turns out.
Don't forget Brafasco has tins of this stuff. It's pretty pricey though - $25 for a small tin.
ok. I tried the plasti-dip stuff from Home Hardware last night. some notes:
1) Fumes - the stuff is highly hazardous. It smells like a combination of burning rubber and heavy paint. One can fumigated my whole house for 5 hours. Be warned. It is toxic as hell
2) It's very very gloopy. It's really thick stuff. As a result, it simply doesn't run off springs because it's so thick. Instead it drips from one ring to the next, resulting in drip lines.
3) iT WORKS. My results aren't perfect, but it's a hell of a lot better then what I had before. Looks great at 5 feet. When you go closer., you can see the imperfections because of the dripping.
4) The stuff takes 5 hours to dry hard enough, and when it does dry, it's really rubbery.
Sounds promising. I'm just planning on dipping the end of my sidestand in the stuff to preserve the powdercoating and keep it from rusting. So I should be ok with the dripping business. Let's see some pics! Any details on the product/pricing?
