Anyone know How to Remove the Cam chain on CL175?
Sean1973
Hello, I am trying to replace the gaskets on my 1973 Honda CL175, and I don't know how to get the cam chain off. I have taken out the tensioner bolt, the tachometer side and points side off the head, but the chains still pretty tight. Is there something I can do to loosen it more? Thanks
Turn the cam chain and look for the joint clip. Remove that and also take note on what direction the clip is facing (should be opposite of rotation). Need to instal it back that way.
IIRC, the tensioner bolt just puts constant pressure on the arm. So you would need to actually push the arm in by hand, then tighten up the bolt to hold it there.
But it has been a while since I've done it, so I could be wrong.
