Arctics New (old) 1973 CB450 tiny progress
thearcticsea
I just picked this thing up for a song.
In the photo I'm pretty well exhausted after kicking the thing over for 20 minutes till it finally fired up.
It sounds fantastic though.
Soon I'll begin the disassembly and collecting necessary parts.
Hopefully the project will be done for the next riding season (about a year from now). The final project will be a mix of restoration and cafe racer mod. Frame off, full-on rebuild.
I've never done a project like this before. Only worked on new bikes, modded new rides, etc. Even so, I can't wait.
Re: Arctics New (old) 1973 CB450
These CB450 are great bikes for cafe projects. I just finished mine this weekend. Biggest problems with these bikes are the cams and cam followers (tappets). They wear out very quickly if the clearances are to tight.
Enjoy your build and post pics, please.
Welcome to the site. The450s are great bikes. One of the best looking motors ever IMO. Keep us updated!
Hey to all you knowledgeable guys. Looking for help.
The night I got this bike I got it started after a long session of alternately kicking and trying the starter.
Now a couple nights later I put a new battery in it and I can't get it started. I don't think the battery is the problem, I stated that because I thought the battery would help with starting.
Anyway, I'm at a loss. The starter seems genuinely fucked. When I press and hold the button I get a whining, whirring noise and sometimes a grinding high pitched squeel.
So I then move on to trying to kick the bike over. Sometimes it catches, sometimes it seems to not catch, sometimes it sounds like it's spinning the starter motor.
Any ideas?
Re: Arctics New (old) 1973 CB450 HELP!??
Does the kicker have resistance when you feel like its not catching. If not then the kickstarter gear could be broken. As far as the starter goes it could be a bad starter clutch. I'm sure someone with more honda experience will chime in soon.
Yes, it sounds like the starter clutch. I had the same problem and had to replace the clucth. One of the roller springs broke and caused the
problem.
So between siding the new house, trying to figure out what's wrong with my pool liner, painting my Triumph and fixing my broken Volkswagen, I've had little time to work on the CB.
However, I was sick of looking at it longingly as I passed through the garage on my way to another project, so I decided enough is enough.
I called a guy locally who's going to help me get the motor in top shape before I start any serious teardown and rebuild work, but I at least started screwing with the seat.
I'm keeping the stock seat pan so that it has that nice factory feel, but reshaping the stock foam and reupholstering.
I'm using dark brown antique leather and I'm going to rim the seat with large, darker brown leather stitching.
It's a style I've pulled from the very classic 1949 Ferrari Touring Barchetta.
In this picture the stitching is red to match the paint, but imagine Darker brown around the outside edge of the CB's seat.
And these are the shots of the somewhat shaped seat foam. Still quite a bit of work to go, but I'll have updates in a week.
If your cautious (somewhat), a disc sander on a power drill does wonders for smoothing that foam. Medium grit and light even passes. Love the shape it is taking.
Well well well.
So I've been doing a lot of work on this bike since I last posted. Things have, of course, impeded the quick rebuild I had planned. But I'm still faithfully plugging away.
I have a quick question for you wise dudes.
I was taking the covers off the motor for polishing and general cleaning and gasket changes and when I pulled the cover thats connected to the left side of the rear cam it suddenly popped off and I heard some things clatter around a bit inside. I had the cam covers off for the same reasons, so I looked in there and saw that the torsion bar that actuates the valve had fallen off of its position. I put it back onto its shaft and starting wiggling the adjuster on the outside. The torsion bar pivoted back and forth in the travel of what I'm assuming is the normal adjustment range?
Either way, I decided to just remember it for later and continued polishing. I just finished that cover and slid it back on temporarily, but I decided I'd come on here and pick your brains.
I didn't do anything too bad right? Once I button it all back up I'll just do some adjusting to get the valves right?
Thanks. I hope I've explained it okay.
I'll post pictures of the project a little later, in case anyone's interested. It's slow, but fun!
