are cb360 hubs symetrical?
overdraft
Coast to Coast
does anyone know if cb360 hubs are symetrical? i'm pretty sure i'm deleting my speedometer and therfore my speedometer drive, so i got to wondering if a second brake rotor would bolt right up to the other side or if the speedo side of the hub is different...
just look at it...
the rear hub is not symetrical, its a drum brake. The front may be symetrical... i cant remember. You can mount up a second disk without removing the speedo drive on all the other single disk hubs (CB450 550, etc etc).
again, a quick look will solve all your problems. If your really unsure, take the wheel off and try bolting the rotor on the left to the right side.
if you really want dual disks look for forks off a 450...
the wheel wont need shimming so all youll need is the 450 trees and forks, another disk, larger master cylinder, and the lines, of course.
