assembling 7" headlight
bigmd
anyone have a step by step on how to assemble round cafe light? I just received my bucket from DCC that came with trim rings screws and some retainer clips.the only thing it didnt come with is instructions.thanks in advance
I use two retainer clips, there should be a spot in the bezel to hold one of the 3 tabs on the bulb. I also think the clips are too long, so I cut about 1/4-3/8" off the ends before snapping them in place, they basically push against the inside edge of the bezel and down onto the flange on the bulb, place them at the nobbies on the bulb, and they'll hold in place pretty well
You dont even have to cut the clips at all, just place the headlamp bulb in the trim ring, and evenly space the clips supplied, clip in one end of each clip first pointy wire end facing away from the bulb, the clip will only fit in one way, youll figure it out, then force the other side of the wire clip down until it clips under the lip of the headlight ring.
