Avon Tire Direction
66replica
The Wrecking Crew
DTT BOTM WINNER
Does the tire direction matter on my avons? All the ones I've seen have been mounted this way:
Is that correct or does it matter?
Yes it matters :) There are directional arrows on the sides. On the universal sizes of the Avons you will see both Front and Rear arrows, pointing in opposite directions.
The front tire is on correctly. Lets see the rear.
BTW - you're not going to create a black hole or disrupt the space time continuum or anything - so long as its dry you're ok. It's when it gets wet that it would start to get interesting.
for the front tire, the channels should channel water towards the outside. on the rear, they should channel to the inside (center)...
the rear thing is a more recent phenomenon. they found that by channeling water to the inside on the rear, you get more grip in the turns where you need it.
OMG, That's almost exactly the same color as the 350 I rebuilt back in .. never mind when.. and sold it to finance a set of race leathers so I could go and, of course... race.
