Bare bones wiring/ kind of
JRK5892
Over 1,000 Posts
I need to re wire my bike.. any tips or tricks on this... i am not going to be do anything to tricky... just very basic... no turn signals, only brakes and headlight... any tips or tricks
TX500 1974
i was going to make the new wire set up off the bike and the put it into the bike... could use any help!
Get quality wire - I used tinned marine wire - 16 gauge I think. I got a lot of my bullet connectors from www.mikesxs.com and Z1 Enterprises, and heat shrink etc. from www.cabletiesandmore.com and locally at Sayal Electronics.
Call me stupid but what is tinned marine wire? how could they tin the whole wire if it has insulation on it? wouldn't that make it very stiff? I use automotive primary wire and tin it myself. I avoid bullet connectors unless I need them, I prefer molex style connectors. heatshrink is a must. and I always sneak an embeded computer or two in there somewhere though that's not usualy needed.
well i will solder up as much as possible... for conectors i plan on using Radio shack plug style conectors... i do want to have all new wire! where would you recomend purchasing it? I just need a bare bones wire scematic for what i would need to run... the bike, headlight, and tail light... i am still not sure about turn signals... who knows... i may just clean up and use the stock set up... i have to lay that all out and see how it looks first... i have not wired a bike ground up in some time now and want to be sure i am up to date on how everone sugests doing it for these old bikes... on most of my chopper kits i get a wire kit for them... but that is not avail on this style ride... guess i am a bit nervous to make sure it is perfect... come to far to have sloppy wires!
if you go with automotive primary wire you should be able to pick it up at any hardware or autoparts store. what about the charging system? electric start? horn? neutral light (you need this one, trust me I have the scars to prove it.)
I got Ancor tinned marine wire in 16ga. You can buy it at marine supply places or online lots of places.
http://www.westmarine.com/1/1/1754-primary-wire-16-ga-purple-per-ft-from-ancor-marine.html
Each wire in tinned marine wire is tinned seperately. Apparantly great corrosion resistance and is actually more flexible I think than standard wire. It's really nice stuff and comes in a wide range of colors.
well no horn... but yes electric starter (in case the girl wants to ride it) and i will deff need a charging system... sorry if i was a bit confusing in my post... i know when i wired my CB750 bob a few years ago i had a PILE of extra wire... there was just a ton of un nessassary stuff there
thanks for the link!!!
it is a TX500, 1974 yamaha... no i do not have a wire diagram... struggling to get one... it is a magnetic i am pretty sure... i have a TX750 diagram and have been looking over that, however it is not in color of course. ha ha ha
the bikes i have been working with are mostly electrinic ignition, bare bones choppers or cleaning up existing wires on harley's the yamaha for some reason is a bit intimidating i have to say... lots of little things that i know if i skip or try to wire out will ruin me
This is posted as a 1973 tx500 diagram.
http://server6.theimagehosting.com/image.php?img=xs-tx500.63-79.JPG&album=25062
BTW - this is the diagram I cooked up after many many hours of eye strain and questions. It's what I'm building.
man that is perfect! that will work just the same for my ride brother! very sick! thanks man i am going to copy that sucker! thanks again!
Well I haven't finished mine, so no guarantees! But it's been reviewed again and again, and should be fine.
BTW - I did it up in Microsoft Visio. I can post the Visio format file if you want so you can make changes to it (assuming you have access to Visio)
