Good article, Von. I'll give you a simple run-down of how to tell if a battery needs to be replaced.
1) Check fluid level on side. It should be between the marks indicated. If its below them, then buy some distilled water and fill to the required level using a small funnel or large syringe. YOu need to do this to each seperate compartment, there will be 6 little screw-caps (on a 12v battery) allowing you to fill each little compartment. 6 volt batteries have only 3 little caps, but these will mostly only be found on bikes made prior to 1970 and small capacity 2-strokes.
2) If this doesn't help the battery start your bike, then have a look at the plates inside it by looking in through one of the screw-caps. There will be plates aligned vertically, they should look blackish. If they look white or light-brown in colour, ensure the fluid is at the correct level and put the battery on an overnight charge in an area free of ignition sources (eg pilot lights, electric heaters etc...batteries give of flammable gas when charging). Try it in the morning, it should work.
3) If it still doesn't work after all the above and cleaning the contact points to ensure good current flow, then its new battery time. Similarly, if the rejuvenated battery initially works but doesn't want to hold a charge (eg works to work but not on the way back, doesn't kick the bike over after a few days sitting etc) then its cactus and you need to buy a new one.
To reiterate: 1) top up fluid to required level with distilled water, 2) put on an overnight charge, 3) if it still dies after all this then replace it. Any more questions just let us know.
Cheers - boingk
