Battery AH Ratings Question
timeconsuming
Foolish until proven intelligent.
Hey guys, very new to the site (and to bikes in general) so excuse my ignorance as much as possible!
Anyway, I have a stock size battery in my '75 cb400f, which is 12v - 12ah.
I'm not sure I completely understand the ah rating, though as far as I can tell it's sort of a storage capacity?
Basically I have a decent amount of electrical running on the bike (starter, blinkers, headlight with no off switch, tail light, kill switch, stock regulator and rectifier, etc) and I'm in the slow process of gathering understanding on how my electrical works and what is essential vs. nonessential.
Is there a reason I should stick with 12ah? Or how low of an AH rating can I go but I need to start slimming down my electrical gadgets?
Thanks for any and all responses!
It's going to largely depend on the health of your charging system. A/hr is, indeed, the rating of the battery to store electricity. In our older machines, it was necessary to have a high rating because the charging systems didn't always charge the battery at low RPMs and the regulators didn't do an awesome job of limiting current at high RPM. A suitably large battery solves both of those issues.
If your charging system is capable of putting out around 60 Watts at idle, then you'll probably be fine with a smaller battery and a modern regulator.
The best way to test this is to take a multimeter to your battery terminals when the bike is turned off. It should read almost exactly 12.1V if the battery is in good health and hasn't been on a charger (or had the bike running) for the past few hours. Start up the bike and let it idle. If it's running at around 14V that's a good sign. After letting the engine warm up, rev the bike up to 6000 RPM or so. Voltage should stay at or below 14.4V.
If both of those requirements are satisfied, you can probably go as low as 6A/h if you plan to keep the electric start or even down into the 4A/h range if you're going kick-only.
If your bike isn't producing enough voltage at idle, you can try LED replacements, putting the headlight onto it's own toggle switch, etc. If you're producing too much voltage at 6000 RPM, you're going to want to upgrade the charging system (specifically the voltage regulator(s)) to something newer.
Another question:
I have been considering updating the regulator and the rectifier with a modern 2 in 1 setup ( such as this: http://www.dimecitycycles.com/vintage-cafe-racer-caferacer-bobber-brat-chopper-custom-motorcycle-electronics-parts-honda-cb350f-cb400f-cb500-cb550-cb750-rectifier-864218.html ).
Is the charging system reliant mainly on these pieces? Or is there another piece of the puzzle I may be missing? Only other thing I was thinking was the wiring, as I've read my bike's stock wiring harness has a lot of redundancy and can aid in voltage drain.
Thanks for any response!
Sonreir has good info, but I think he meant 12.6V for a good, fully charged lead acid battery. Below 12.0 volts is a fully discharged battery. Above 12.6v is what is called a surface charge. After coming off a charger, it will have a slightly higher voltage. After sitting for a few hours, the voltage will normalize to 12.6, assuming a good condition battery.
Voltmeters are not perfectly accurate, so 12.5-12.7 is indication of a good, fully charged battery.
Yes, your generator and your grounds are very important as well. You will want to test your generator (or alternator or dynamo, depending on who you ask...all the same thing) to make sure it is putting out the proper voltage and current. A new battery and regulator/rectifier isn't going to do you much good if your generator is shot. Make sure your harness is healthy and all of your grounds are present, clean, and tight.
Thanks for the responses guys, I'll go pick up a multimeter and run some tests (and scope out my harness) before buying a new regulator/rectifier.
Finally managed to run some tests. The battery was at 12.6v which was good, then at idle it was anywhere from 13.9-14.4v which seems good. But at 6k rpm revving it jumped to about 15.3v but stayed there pretty evenly until I let off the throttle and it made its way back to the previous idling voltage.
Any idea what that means? I just installed a modern regulator/rectifier combo and am curious if I'll be good with a 6ah battery (keeping electric start but not always using it).
Thanks guys.
