Battery Box Relocation and Mounting
stpilotdesmond
Active Member
Its seems that most people move the battery down to the swingarm, but I want to mount the battery outside on the left side of the frame. I'm going to have a 2 - 1 exhaust on the right side, so I think the battery on the left side will look good, plus it's different.
I have questions about the regulator and rectifier that were mounted to the stock battery box. Were they mounted there for a specific reason? Can I just move them to anywhere on the frame? The original battery box has rubber mounting points with metal inserts (the metal does touch the frame) and everything bolts to the battery box (rectifier and regulator) except for the starter solenoid. So in theory I should just be able to bolt things directly to the frame, right? (except for the starter solenoid.)
Thanks for you help... it's much appreciated.
Oh and here's a pic of my progress so far. The things that are giving me the biggest trouble right now are re-upholstering the seat (no idea how to do that) and figuring out this battery mount and relocation thing.
I know the rect needs to be grounded to the frame, but i dont think the regulator has to. Double check the wiring diagram first though. Both need to have some air flow around them too.
Buy a gel battery. Mount it laying down.
Here is my 360 to show you what you can do with a shitty ol welder. I tucked EVERYTHING under the seat.
stpilotdesmond said:
.....I want to mount the battery outside on the left side of the frame......
Do you mean outside the frame on the left? Sorry dude - I can't see how this would look good at all ???
