Battery dying on CB350
72texas350
I can't figure out what is going on with my battery. I have a Ballistic EVO 4 lithium battery and it keeps dying. It is a brand new battery that hasn't been used for more then 5 minutes. The bike has a new, to me, engine that I just put on. Could it be possible that the engine just isn't charging the battery? How do I check to see if that is the case or if the battery is shot?
You're going to need a multimeter. A cheap one will do. Then use the troubleshooting chart here: http://www.electrosport.com/media/pdf/fault-finding-diagram.pdf. If you end up doing the test where you bypass the regulator, be very careful not to rev the engine past 1200 or so or you'll blow every bulb on the bike and maybe the rectifier too.
And none of the tests will work if your battery is dead to begin with. Charge it fully with the appropriate battery charger first.
I figured it out. Thorns out it was my own stupidity ☺. I had connected a wire wrong since it was the wrong color from a previous owner's swap. Thank you for your help!
