Battery Mounting Position
johnu
Over 1,000 Posts
DTT BOTM WINNER
Is the battery in the pic below safe to mount how I have it positioned. It is a power source sealed battery.
As long as it's not flopping around it should be safe. Mount closer to the center of the bike, if you can. It'll be better for the weight distribution.
It's where I've had my battery for a few years on my XS.
What's the bottle for? Coolant? If you want a much smaller and lighter battery you should check out the Shorai Lithium Iron line.
I really would like to have it in the centre of the bike but I am going for a minimalist look. I know form follows function but in this instance I will have to make a small sacrifice knowing now that the battery can be laid on it's side.
My original plan was to use a Ballistic battery but I can't justify the expense at this time.
The plastic container is the 2stroke oil tank.
