Battery Negative/Ground Connection (Update)
johnu
Over 1,000 Posts
DTT BOTM WINNER
Can I just run a wire from the negative side of my battery to the frame then attach the negative from all of my other components to any bolt on the frame?
Re: Battery Negative/Ground Connection
Yep.
In fact I think you will find that every car and motorcycle is done just that way :)
unless its a positive ground , those nasty peeps.. i think some brit bikes are like this.
Thx. I got a mess of negative wires going everywhere, some going back to the battery some to the frame so I am going to tidy everything up.
A common ground back to the battery is always better more so for for the important or more sensitive bits like your ignition. If you use the frame, just make sure there is good metal to metal contact at all points
A multimeter is a good friend for checking how good your connections are. You can look at both the resistance of the ground path and the voltage you see at the end of the wires. Also, cleaning paint / corrosion / wasp nests off your electrical connections is helpful in reducing voltage drops.
One ground cable to the engine and a second one to the frame is fine. But a common grounding buss bar works a bit better, your grounds all run back to a block that is directly connected to the negative battery lug with a 10g or 8g wire. Frames can have a lot of hidden corrosion, loose fasteners, etc that mess with the connection.
And as far as positive ground goes, same principle. One of my trucks is 6v positive ground, may stay that way since I found a dual voltage, dual polarity radio (AM mono only, but the truck is from the 1940s so it doesn't matter) in my odd parts boxes, saves me a bunch of headaches converting everything to 12v negative ground.
Ok thanks for the replies. Here is my plan (see pic below); I have sanded the powder coating down to bare metal on the bracket that is holding the rectifier and added a 6mm bolt which is captive to the bracket (it's the one sticking up with the plain nut on it. I plan to run the heavy groung wire from the engine to this bolt, also the heavy wire from the negative side of the battery and all the other grounds from lights and components. I think this is what you were all saying.
Going to steal your idea, I too have been thinking about where to run all my ground wires now that I've put in all new lighting and gauges. Really seems like Honda over wires their bikes.
That should work fine, although, a copper washer under the bolt head and under the plain nut would enlarge the grounding point and allow you to brush paint the rest of the bracket for corrosion resistance...
Thx, will do the copper washers, not really worried about leaving the metal bare it is under the seat and corrosion is not really an issue here in SoCal.
