Battery question... setup specific..
expelled
Active Member
ok guys.. I know we see these a lot but I needed some answers for my specific setup..
76 cb200t
head and taillight (no indicators)
I am KEEPING electric start
will be using electronic ignition (does it make a difference?)
I haven't fabbed a batt box yet and I would prefer to have a very minimal one. what battery can I run that will still be able to crank over the electric start? I do have a tender and can keep it hooked up when I'm not riding..
Can I run a small pack?
thanks!
Just about every electric start will need around 70 amps initial current and 45 amps while turning engine over.
Usually the smallest battery that can do it and still run bike will have around 130~150CCA, probably around 6~7amp/hr, depending on manufacturer.
I have several 8A batteries which will 'do' 200 A/hr.
Use the smallest battery you feel comfortable with but be prepared to redesign for a larger one
Look at the stock battery as a starting point and see what alternatives are available slightly smaller. You can probably go down one size in Amp hour rating if you need to, but don't go so small that the battery dies every time you ask it to kick the motor over.
Should be able to get away with a 6Ah battery really, I mean I ran a 125cc single-cylinder two-stroke with electric start and full street lighting for 12 months without a problem... on a 3Ah lead-acid battery.
I see no reason why you shouldn't be able to get away with a 6Ah battery for your build, especially if its a high quality sealed unit. If you plan on only using kick start then I would suggest a 3Ah battery, purely because any less will probably be inclined to overcharge and either boil itself dry or explode.
Cheers - boingk
Nope.
It only has 35amp terminals
boingk
A twostroke has lower amp draw as compression is much lower at cranking speed compared to a fourstroke motor.
Pretty sure the smallest you can use will be about 8 A/hr (but if it don't work, it's not my fault :D)
You could always go to a battery shop, (anywhere with an inductive amp meter capable of 100 amps)
Take bike and get them to measure initial amp draw (you could use a shunt and measure milliamp current which would be the same)
I'm not going to try and explain it online
just man up and go kick only. saves weight, looks cooler, more reliable, smaller battery, one less thing to worry about.....
only time i would want electric start is if i stall in traffic... but even then, if your bikes running good, one kick is all it would take. or learn to not stall. :D :D
Rocan said:
only time i would want electric start is if i stall in traffic............................ if your bikes running good, one kick is all it would take. :D :D
........................................................................after you find neutral ;D
I had ignored that aspect of it. It's only a CB200 after all. How hard can that be to kick start? If the bike is hard to start, now would be a good time to fix that. If you have a different issue - like no strength, broken leg etc, that's a different story, but for most of us a kicktarter should be fine.
If you really want a small battery, look at
