battery question
supercafe
Coast to Coast
hows it going, i have a cd 175 cafed out. the electronic sys is 6v, my batt is dead and was told that i could run a 12v batt
inthe place of the 6v batt. could this work????????????????????
would be easier to get than the 6v.
on another note, i was on a drive and my bike was acting up. first it would stumble but after awhile it would just die on me.
while coming to a stop, very hard to get it started, boosted off cars to get going. started looking at it and found the main wire
from the points broken holding on by abit of the wire. fixed the wire. started again, had to boost it, pretty sure i need a batt. while running it still has a stumble with it, sounds like a fuel prob. so i took apart the carb and checked the float looks ok, checked the main jet looks good. the float bowl gasket would leak if i blow into the breather tube attached to the bottom of the bowl, fuel leaks out the bowl gasket, could this be a vacume leak???????
also could the batt cause the bike to stumble, being no good?????????????????
well, if any sugestions they would be great. need to fix this problem..
later.
Sure you could use a 12V, just get one with the same amp rating as your old 6V. If you get a 12V with a higher amp rating, the stator may not be able to keep it charged. Of course you would need to replace all the 6V items such as light bulbs and regulator with equivalent 12V parts.
thanks DrJ,
i would rather install the 12v, lights would be brighter, etc.
it sounds pretty easy to do awell. all bulbs and regulator and thats that, very do able.
one question the regulator, could any one do say like off a 350/400 etc...????
or even a 200 they should be 12v..
you have been very helpfull. did not know this, thanks again.
later..
