Battery Recomendations for CL350?
Zags
Hey guys, I've got a cl350 project that I need a battery for. Preferably one that's small and easy to hide. Something flat, like a laptop battery shape would be ideal. The bike will have an electric starter. I've very new to this and not even sure what I really need though.
If someone could point me in the right direction I'd be grateful... thanks!
LiPo or LiFePo is a no-no for 350, the charge/discharge is too specific for the old charging system.
Using the electric starter you will probably need a minimum 10A/hr batter (stock is 12A/hr) particularly while your troubleshooting after modifications. (do a search to find LiPo battery issues people have had)
You can get an SLA/GRT battery which is smaller than the original
If you decide on a small LiPo, also figure out where to put the fire extinguisher.
Here's my recommendation.
Go buy a cheap lead acid from auto zone and use that to get the bike running perfectly.
Once you've tuned it to start on a 1/2 push of the button then switch to a small Li-Ion battery and call it a day.
A good r/r (like the one at Sparckmoto) is needed regardless of the battery. For reliable running, the oem size 12ah, 120 CCA will give the most reliable performance. Cb/cl 350 needs good voltage to run well. A small battery can run down faster. It has less reserve. It may an the difference between riding home or pushing home.
Sent from planet Earth using mysterious electronic devices.
