Moondogz said:
I have a similar issue and I am trying to use a tiny sealed battery pack. I have seen the battery packs used, but I have been unable to source them. (See my post in this same forum)
The battery pack idea may also work for you, no starter motor and such.
Im puttong one of these in... shed 10 lbs of the bike,, the battery is 11 onces!!!!
The new incredible superlight Speedcell SS battery produces 1.8 amps per gram of weight.
The SS battery is a 120 Amp Battery, weighs 11 OUNCES.
It's durable: 1% total capacity loss with stop loss at 2% so it never drains down to zero.
No maintenance: The battery does not need to be on a trickle charger. If it ever needs re-charging, just use any 5amp or higher charger.
Safe: These packs are made using A123 cells. The constructions process is proprietary & these packs do not require balancing. The packs are built for motorcycle applications w/ cylindrical cells due to there robust construction & discharge properties. Each PACK is made to a DoD standard, capable of withstanding 100G load, operating temperatures of -50*C to 49*C (-58*F to 120*F). It is important to understand that these packs are NOT RC hobby type packs & their internal construction as well as cell grade reflects this. Each cell is individually tested before it makes it to the construction phase. These packs are not Lithium ION construction. Speedcell uses Lithium Ferrous cells that are not volatile or unstable. They will not rupture when punctured nor produce an energy chain
SUPERSPORT Specs:
- Pulse discharge @ 10 seconds = 120 Amps
- Continuous discharge (MAX) = 70 Amps
- Cycle Life (DoD spec) = 1,000 cycles
- Dimensions = 10.5cm (L) x 2.5cm (W) x 7cm (H)/ 4.13" (L) x 0.98" (W) x 2.75" (H)
- Weight = 337.36g / 11.9oz
- Rating = 2.3Ah
- Applications: 2 and 3-cylinder engines up to 600cc/ 750cc 4-cylinder with stock compression and stators.
The 2.3 Ah SS battery is designed for 2 and 3-cylinder engines up to 600cc or 750cc 4-cylinder with original compression and stock stators. For 600cc twins or larger, Triumph 675, or high compression twin engines use the SpeedCell SBK Battery .
For some street applications, the 4.6 Ah SpeedCell SBK Battery is a better choice since it provides twice the reserve capacity (4.6Ah) and starting power which would come in handy if you have any failures in your charging system or if you forget to turn off your bike. If you have modifications to your motor that can make starting more difficult, get the larger SBK battery.
For modified engines larger than 1000cc, consider the new 6.9 Ah or 9.2 Ah Speedcell batteries. Prolonged repeated starting attempts on a smaller Speedcell battery than recomended can overheat and damage the Speedcell battery.
If you get the SS battery and it takes more than two or three cranks to start the bike, we will upgrade you for the larger battery - just for the difference in cost. We will cover the shipping out to you the 2nd time.
More pictures:
http://www.motowheels.com/italian/mySearchResult.cfm?parentcategoryid=&productID=6815&showDetail=1&categoryID=143|Ducati%20Monster%20Electrical&vendoridtodisplay=0&filterFor=speedcell&collection=
