The only difference a smaller or bigger battery will make is it's capacity. 12Ah batteries can give 12 amps for a total of 1 hour, 6Ah batteries can give 6 amps for 1 hour, or 12 amps for 1/2 hour (you see how it works?). So, the battery only works as a storage tank for current while the bike is running. It smooths out the pulsation from the charging system at lower rpms, and when at a low idle will give an extra little kick to the system as the generator won't be putting out full capacity.
Think of it as a pail of water. Your charging system is pouring water(current) into the pail (battery) at a certain rate. The coils and lights are taking it out at a certain rate. If it's going out faster than it's going in, your battery is gonna be empty at some time no matter how big it is, and your charging system will likely fry trying to keep up.
Running LED tails and turns can help with lowering the current draw on your system. As well, putting a 55/60 watt headlight on a stock designed 35 watt system will likely cause some problems.
On another note, a bigger battery will provide more cranking amps for electric starters.
