ariel.714 o/c
Monkey see monkey do is all i see now days!
my motorcycle battery has this on it (12V/6AH/10HR) does this mean i charge the baterry for 10 hours at 6V?
(12V/6AH/10HR) That is what is printed on my battery. I charged it for ten hours last night @ 12volts and everything fired up.crazypj said:What are the actual battery numbers/letters as printed on it?
You probably need a different charger.
A sealed battery will tell you charge rate, a conventional battery needs one tenth the amp hour rate for 20 hrs (0.6amps)
1.5 amps is more than double the requirements, causes the insides to overheat and possibly short circuit (then it explodes ;D )
You could probably find a 600milliamp phone charger/low voltage lights or similar (any 12~14v power 'brick)
Just check which side is + before you cut terminal off and fit alligator clips (or get the cheap battery maintainer from Harbor Freight)
stript.714 o/c said:@ KONG : Thanks for the helpful info . so really quick my battery is a (12V/6AH/10HR) battery and my charger is a( 1.5 amp maintain) & its out put is 6/12v dc at 1.5 dc . Will i be ok charging with this charger for ten hours?
