Bearing grease inside engine what to use
MB
Coast to Coast
I have to reinstall the bearings in my crank. The grease I have on hand is a high temp lithium complex. Is this suitable for use inside my cb450 engine?
I need to pack the bugger with grease to get em' to stay in whilst it rotates
Suzuki says not to use engine assembly lube to put an engine together, as some of them have molybdenum, which is a friction modifier that will royally screw up a wet clutch.
Having said that, plenty of people have used it without a problem.
I use a little petrolatum for this purpose. Don't use lithium grease. Again, it ain't good for the clutch.
That's odd. I was a tech at a Honda/Yamaha dealer and both of them reccomended moly inside engines. In fact, I have a tube of moly grease in the shop and it's Honda branded. I've heard of moly problems with wet clutches, but never saw it linked to assembly lube, only motor oil.
I use this stuff called Transgel. No friction modifiers and it turns into whatever petroilium product in touches. It's mainly used for automotive transmission assembly, but works real good for holding bearings in place till engine is assembled. Also use it for new automotive oil pumps so you really don't have to prime them. http://www.handsontools.com/Kent-Moore-J-36850-A-Transgel-Lubricant_p_13139.html
I'm just doing my engine now and am using Lucas Assembly Oil. Nice stuff - sticks to the gears and bearings well. Have no idea what it will do to my clutch :)
Just on the gears, bearings, maybe some on the camshaft lobes. The pistons will get some motor oil.
I just used good old high temp axle grease, I have plenty around. That's what I have built plenty of engines with. Dad used to swear by Motor Honey, back when you could find it easy.
Most major parts stores carry Motor Honey, like Autozone and Advance
No need to use grease on main bearings?
I just oil them, or, if it's a problem, use petroleum jelly as it won't block any oilways plus melts easy in oil
PJ ftw. Vaseline is fine - just enough to hold them and no more. Grease often clogs oilways and that's not good.
Don't put it on the clutch then ;D
You'll be using such a small quantity it shouldn't have any effect on clutch plates
