Beat The Clock
Re: 360 beat the clock 06.11.10
Progess: DAY II
First a little better shot of the finished backbone down to the lower support. the coils will be mounted in the space between the backbone and the motor just above where we put the batterybox
decided to weld the battery box in. I wanted it to sit very low between the frame rails. The coils will mount above this to the engine side of the backbone. Nice perfect space there.
Gusset under the seat is done. ( I know... I need to trim the length of the seat bolts) Anyhow a few more gussets and the brake mount and time to tear this puppy down
Ethan putting some black lines on the tank. Once dry he is going to lay down some white to match the grips.
I love these late night updates Troy!
That tank's going to look great. Along with everything else of course.
Thanks man. Ethan was putting on the white when I left tonight. It really made it pop. Anyhow, pushing to get this thing done before the GTT.
looks awesome! have him do a white and red strip on the wheels like my Harley has man, all you have to do is lift the bike so the wheel spins free, have him hold his hand static with the pin stripe brush and slowly spin then have him move in 1/8 and do another stripe (if you use the red and white that will really tie in the tank and the striping and give it an off the wall look, in the 70's my dad used to stripe all his frames as well, gave it a crazy cool effect
now man that you have this sucker so long, you got to beeeef up the front end man, do what we talked about months and months ago... will really fatten up the front and look trick. LOVE THIS build man
if you look close you can see the striping on the frame
Re: beat the clock RIP 07.14.2010
Thanks fellas. Much appreciated. Today is the day that Beat The Clock officially died. Today I finally accepted the fact that this bike is 100% different than BTC and it would be wrong to call her by that name. Not sure yet what to call her but she deserves its own name.
Hey Joe I love the idea of striping the wheels. I'm kind of pressed for time to get this baby rolling by the get together so striped wheels might be somethng to look into in the future.
Biker_Reject I'd love to say that I did the welds on this bike. Jason is a welding fool. Brothr has some mad skills for sure. You know this project has been a blast and I'm so glad I got him involved. Besides him having awesome fab skills It is so cool to put our heads together and come up with different ways to do something. Its just been a freaking blast.
Thanks again for the props guys. It really means alot!
Well I feel we are over the hump. I should be able to hand Jason the frame tomorrow so he can finish up some of teh welds and to finish some gussets
Front Gusset finished. He is going to run a bead down the lower factory gusset to strengthen it up and tie it in with the raw look of the rest of the welds
Gave Ethan my helmet. By the way he will be at our get together on Thursday and Friday ;D
Purchased a yoke from a local parts store. Then the linkage rod had to have a couple very slight bends. We wanted to use a heavier rod to stand up to the stresses so we machined (used a grinder) to take the ends of the rod down so it could threaded. Worked pretty slick. Anyhow, Jason welded a tab for the return spring on the brake lever. Turned out pretty sweet.
I love where we put the brake switch. It is hidden under the frame back near the tire instead of up around the brake lever. It will be activated from the linkage. Split a washer and welded it to the linkage rod.
Frame gusset finished. I'm pretty stoked about these gussets. WE split some pipe so that it would have a radius on the top then a small triangle was cut to fill in the side. I love how these turned out
Welded a tab for the new exhaust (this was taken after both pipes were finished. We removed them so this bracket could be finished)
Welding up the new exhhaust
The ends of the exhaust are not finished but this gives an idea of what it will look like. Plan is to weld some bungs on the pipes. Split a piece of stainless and make a couple of heat shields
made a mount for the coils. Have to give Kiley partial credit. I was considering spliting some pipe and making a mount around the coils Kiley said why not just slide the coils into that pipe then find a way to mount that to the frame.
I headed to the muffler shop and picked up a piece of stainless.
Split a piece of pipe that fit the frame and cut the stainless to fit the coils
Jason welded them up to the split tube and then welded a bolt so it could double as an engine mount bolt. The mount is all hidden. I freakin love how this things look
Cool little brass Hodaka pet cock was hitting the top of the motor so I had to put a 90* in. For some reason there wasnt one on the other side of the tank and no cross over tube so a new old stock is on order. Anyhow, I really like how this thing looks
Started tear down so the frame could be finished welded. One huge thing I found out is the voltage regulater and rectifier can fit under the tank on top of the backbone so we still need to fab up a couple of mounts. Anyhow this is how I left her tonight and damn am I tired
Its amazing troy!
I also cant believe how fast that kid got at striping so fast...I been playing off and on for a year and still suck!
He rules!
amazing work. purely amazing. The attention to detail, the reuse of parts. so unbelievable. I absolutely love it.
When I read the post header I thought something catastrophic happened, like a fire in the shop or something like that. Glad to see it's only a name change.
Well Troy. As always, amazing stuff. Im really diggging the coil mounts! I cant wait to see this scoot in person! Less than two weeks. This will be great.
I thought the same thing about the title - roof collapsed on the bike or something. Whew!
As always - you and your crew are doing some amazing work. Did you tell Ethan we will probably want bits and pieces striped while we are down there? He could make a fortune off us! ;D
x3 on the catastrophe, don't do it again. Consider yourself warned :D
Hell, my ticker nearly seized, but I guess that just made the update that much more satisfying knowing that the ride was still in tact.
All I can say is:
WOW!!!!!
This thing is a new animal, and really F'n cool!
Hate I won't be making it up to your gathering to meet the girl in person, so you will just have to bring her to Barber in Oct.!! ;D
Great work as always Troy!
After a long night of wrenching my ass was dragging and it didn't cross my mind what that heading was really saying. Hahaha, sorry guys. just time for a name change ;D.
Thanks for the props fellas. Really cool to pour your heart into something then afterwards come on here and have a group of guys "get it". Just awesome!
I'm so glad you guys appreciate our work. Hell we could have had this thing knocked out a long time ago but Jason and I are are common in that we are both kind of anal ::). I love working with him. I know I'd feel the same way working with you all too. We could turn out some cool shit together. Wish we all lived closer.
Twisted I consider that a personal invitation brother. Thank you, thank you! I plan to do my damndest to make that trip. And thanks for the props man. Greatly appreciated. I really wish you could somehow make the trip. It will be so flippin cool to put faces to the names.
And guys Ethan said he can do some striping for us. I know he will be here on Thursday and maybe some on Friday. They are leaving for a show but I'm not sure if its on Friday evening or Saturday. Anyhow I'm sure there will be plenty of time for him to work his magic. Also, I'll have to have jason bring out the 65. I can't wait!
Troy i am a bit worried about a few things, the coils may get too hot in there, you may want to drill some speed holes in it to allow air flow around them. the other thing i worry about is the chain, that is a hell of a distance now you have from the front gear and rear sprocket, i would be worried about throwing the chain, crazy noise, excess wear, and the chain just flapping around. you are going to want to do a tensioner.
the one that i would recomend and use is from cycle exchange
http://www.cyclexchange.net/Frame%20Page.htm
it is in the middle of the page if you scroll down
In the past i have made my own using a skate board wheel all you need to do is groove the center of it, i did it on a lathye but you can also do it if you use a drill press hook the wheel to is and then use a file pressed up against it... will work just as well. then all you need is a scissor style spring. mock up the wheel mounted to a hinge and attach that to the lower section of the rear frame rail, then slide the scissor sping in there to keep a constant tension on the spring. will make your life 1000% easier, and to be honest is a must have on any chopper with a good distance between the motor and sprocket, i am going to do the same on my CB350 bob just so it is not so noisy and stuff lasts longer. the one i made i was in college and piss ass broke, now for 65-100 bucks i will prob just buy it.
ok that is all
oooooh ya! find out from your buddy if he wnats to make some $ i would be intrested in throwing one of my helmets in the mail to be striped man! thanks agian bud looking great as always!
