Because I like posting my CX...
makenzie71
This was my favorite build...and, of the thirty bikes I've owned in my short time, it is second on my three-strong list of favorites (I just can't knock my TL1000S down a notch and my GS750 hasn't really struck the same nerve yet).
The back-story is that my neighbor came over one day and said he was having some trouble with his little four wheeler and wanted to see if I could help. TRying to sort that out I saw a wheel sticking out from under a bunch of garbage. It was a comstar and I have an affection for old hondas so I went and checked it out...it was, indeed, a Maggot. Owner said he didn't know what was wrong with it, didn't have a title for it, and had no use for it....but he needed a lawn mower. I had a broken lawn mower. I didn't know what was wrong with it, either. So in the end, I brought him my mower and I took this home:
http://kaleesphotography.com/photoartclub/showoff/foundmaggot.JPG
(it's huge...sorry...)
Of course there were a number of "stages" the bike went through...including a frame swap to get a title and some odds around that...but what I ultimately ended up with was this:
Full exhaust (30mm primaries and 45mm secondaries and mufflers)
GL500 carburetors and manifolds (spaced better)
Uni-Filter Pods
310mm front disc
2-piston caliper up front
EBC pads up front, and shoes in the back
13" Showa shocks
GL1000 forks and triples
Progressive springs and 20wt
Full GL500 TI conversion ($100 stators and far more reliable)
Powdercoated bits here and there (like the valve covers)
I'd list more but, when you have a bike that's as good a platform as this, you don't need to do much. She did sport some ammo cans for a while, too:
Ultimately, I traded her and all my Honda parts off for my GS750:
Not all that good a pic...and not as cool to look at...but she'd eat my CX and spit out little funky transverse aluminum chunks.
Thanks for reading!
How does the front end hold up without the fender brace? I'm planning on removing my front fender, but I have an aftermarket fork brace to keep everything in check. But I'm curious to hear how yours is holding up without any bracing (aside from the triple tree clamps).
Help up no problem. Crazy thing was that with my GL1000 forks and the comstar, running the 310mm rotor, when I really cranked on the brakes in a good lean the front end would get a little squirrelly when the fender and bracing were on the bike. After I took the fender and everything off she was dandy. Not a flinch no matter how hard I pushed.
How'd that big brake grab for you? I'm looking at a similar upgrade on one of my bikes....
I loved every second of it. I would put it up there as the best upgrade that bike saw.
Cool! I just picked up a CX500, same version as yours AND a freshly rebuilt 650 engine and trans for....embarrassingly cheap.
I need something that'll haul the girl and myself around this summer and ALL my other bikes are setup solo.
I have enough brake parts on hand to set something similar up.
Take NO shortcuts! My setup is using an offset Bandit 400 rotor (GS500 and Bandit 1200 works...plus you can get wavie B12's that just look AWESOME) and a freshly built, excellent condition SV1000 2-piston caliper run by a 5/8" master. You want the 310mm Suzuki rotors because they have the correct 5-lug patter...so you can drill the new 5-lug patter into the rotor and maintain a semblance of balance...best to have a machine shop do the drilling, though.
You will need to beef up the forks if you intend to do real heavy braking. Look for GL1000 or CB900 forks. You can get them cheap.
Before you get too involved in brake upgrades, though, I would seriously invest in getting the charging system upgraded. If you've got the same model as I it'll be a Deluxe...which has a digital ignition. Throw it away...you'll need to get a TI ignition to run the 650 either way. Get a new stator (for GL500 or 650), a GL rear cover and pulser pick-up, and a GL wiring harness.
Of course, that's all my suggestions...but yeah, the brake thing was my favorite modification. Screamed up the mountains with my wife...and folks on GSXR's could shake me coming down solo. I miss my CX.
Good info on the electrics....
As for suspension, I can cover that pretty easily. I've been sitting on a large pile of parts, in this case I don't think I'll put USDs on it but I do have a couple pair of 2000-2001 Triumph Daytona forks (very nice and pretty damned light for non-usd). As for fabrication work, I run a custom fab shop with a decent machine center....I should probably put it to use. Heh. I'll machine up some aluminum triples for it unless I can get hold of some triumph parts.
Looks like I'm gonna have a decent TIG set-up by the end of next week so I've even thought of working up an aluminum swingarm for it. I think I've got an EX500 swingarm that'd be about the right length. Turn up an aluminum driveshaft tube with the flange on the end and weld the two together after a bit of machine work........
Yeah i need another project like a hole in the brainpan.....heh
