Bench sync on a KZ650
Kuyarico
Coast to Coast
I'm helping a friend rebuild his carbs on a 77 (I think) Kawasaki KZ650. We've got everything back together. Does anyone know what the proper diameter bit I should use to bench sync these? If it makes any difference, they're Mikuni carbs. (not sure if that was stock for those bikes)
Hey, I just usually stick the back end (thicker part), of a toothpick sideways into the chamber and adjust all the carbs until the opening just sits on top of the toothpick. As long as the opening in all 4 chambers are all the same, its technically bench synced. Of course you'll have to re-sync the carbs when the sync tool when its running.
We were working off of some documentation from kz650.com i believe, and they recommended using a drill bit of 1/4 - 3/8 in size. Those bits are huge. For my CB750, i use a 1/8 bit to sync as per the advice of sohc4 faqs.
I realize this is a really old post and the issue is more than likely solved already, BUT....
I bench sync'd my stock vm24 carbs on my 77 kz650 using a 1/4" drill bit to set the slide heights and have never put a manometer on them to re-sync them running. Unless it's been sitting for a month over the winter this bike is a one kick start, so I'm guessing that the 1/4" is dead spot on. ;D
