Bending header?
AgentX
Over 1,000 Posts
So in the interest of economy I'd like to use a stock header when I rebuild my Enfield. However, I'd like to add a little upsweep to the pipe just before the muffler attaches. (Single cylinder bike, one header only.)
What's the way to go? No experience with this. I'd prefer avoiding the generic upswept adapters to keep it clean and leak-free.
I imagine any home-tool remedy will deform the pipe, right? Would that be significantly detrimental to exhaust flow?
Can an exhaust shop do the bend properly on the existing header? Should I just buy a short bent pipe from Cone Engineering or someplace, and get it all cut/welded in the proper place on the header? (Of course, then I'd have to get the chrome pipe blasted and sprayed with header coating...or pipe wrap over the welded area or something.)
old fashioned remedy.......pack the header with sand and plug both ends, stick it in a vice, then get the oxy torch onto the area you want bent, heat to cherry red and bend (possibly using scaffold pipe or similar OVER the end nearest where it's to be bent)
the sand will keep the pipe from deforming because it won't compress inside the pipe and allow small gradual bends to be made
alternately a custom exhaust shop should be able to pop it in one of their jig/mandrel things and bend without hopefully damaging the chrome
OR you could have a whole new header made and then you've always got the old one if you want to change back
Thanks for the advice! Am looking at the many options. New mild steel headers with low-quality chroming are nearly free for my bike. (It's an Enfield, and I'm in India at the moment...).
Was thinking that once I'm Stateside, blasting the chrome off one of these, bending/cutting/welding to taste (work tbd by someone else, since I'm not a metalworker) and then just painting the header black or getting it cerakoted would be easiest. Then again, you have to hammer the pipe in and out of the head, since it's just a press fit. I guess neither paint nor ceramic coating would enjoy being whaled on with a mallet. Hmmmmm.
And I'd certainly like having a stainless pipe to go with the stainless megaphone silencer I want, but the cost may be prohibitive. It's only a single, but one-off work is never cheap.
