Best and/or quickest way to strip and prep frame for paint
eightsevenzero
I'm ready to strip my frame for my CB400 and am wondering what the best way is to go about it? I'm going to be repainting it in a flat black rattle can finish, possibly with a grey auto primer in rattle can form first if it's beneficial?
aircraft grade paint stripper... messy but works.
the quickest is to send it out and have someone sandblast it for you. or sandblast it yourself- only issue is having a blast booth big enough to be able to do that.
3M makes a pretty good paint/varnish remover disc attachment for a power drill. i sprayed some paint stripper gell stuff on my parts and then used the 3M disc to strip them down to the metal. worked pretty well for me. probably not as well as a sandblaster would, but it did the job.
Agree with Rocan...
Aircraft stripper in great, super strong and pretty quick. Although like he said messy.
Sandblasting may be the most thorough, but more costly if you cant do it yourself.
If you have an air compressor, get a $40 Speedblaster (ebay or amazon) and a 100lb bag of sand for $5-10. Take it outside and blast the shit out of it. Not only is it stripped, it's prepped for paint.
Gotta say, it's probably one of the best $40 I've EVER spent.
Don't forget to remove the frame plate first.
The rivets will push out then use some dental floss to 'cut' through the adhesive.
A wire brush on a 3" grinder works wonders and is not as messy as using strippers. It's also cheaper then getting the frame sand blasted.
Rider
Funny anwser cutting torch with the oxygen up to high and a wire brush as keep the triger pull run over the frame as soon as the paint turns white brush takes it right off this is also a degreaser lol it works but dont do it we clean paint and grease off of trains before we weld on them but take you advice from the other guys
I've done both stripper and sandblasting, I favor the stripper.
Sandblasting needs a big air compressor, at first I spent more time waiting on my good sized 5-1/2 hp 27 gallon compressor to build back up than I did actual blasting. Wound up taking it into work and doing it outside the back door on a giant tarp to catch and re-use the playsand. True the frame had a great texture ready for priming afterwards but sand trickled out of every tube for days, I thought I finally had it all out until I was painting it. I did the bottom first and rolled it upright to coat the top and more ran out on my wet black paint >:(
Stripping was WAY easier to me, paint it on a section and wait a few, then took it off with some corse steel wool. First pass removed probably 80%, second pass removed almost all the rest. Any remainders in the nooks and crannies or rusty spots I got with a wire brush in a die grinder. Then to finsh I rubbed the whole thing down with paint thinner to remove any residue before priming
I guess total time involved sandbalsting may have been faster, but what a PITA. Just my two cents.
I have one of those cheap airgun blasters so I was just wondering. But sounds like I'll try to strip most of it first then maybe hit the stubborn spots with the gun.
Thanks!
The best and easiest way to strip and prep a frame is to drop it off at you local sandblaster. With industrial equipment they can strip a bike and all its parts in just a few minutes.
I had everything in the photo done for less than $80 and 20 minutes of my time to drop it off and pick it up. Easy, fast, clean and cheap.
that is one thing i should have mentioned... sand gets EVERYWHERE. pain in the ass to clean off. thats why ill never sandblast motor again; im going to do 3 oil changes without even running the bike for very long, just to be sure i got all the bits of sand that i couldnt get after hours of cleaning.
NEVER sandblast you engine or components! I will not even bead blast my internal components for the fine beads can get into the pores of your alloy casings, stay until motor heats up, make their way into your oilway and scar your pistons and cylinder barrels-bye bye power, money and time.
For my project I am going to have http://www.modsrockers.com/ vapor blast all my motor and carb parts. If you want to go the cheap route on motor parts, use 3M red pads for metal, Simple Green and elbow grease. Beer makes it less tedious.
Vapor blasting typically involves using glass bead or aluminum oxide media and you still need to carefully flush any remaining media from your engine parts. Your concerns about contaminating the engine with blast media applies to vapor blasting just as it does to dry blasting methods.
Since the topic is morphing to engine parts, we have had a company solicite for my business on cleaning the machines at work that is using "Dry Ice Blasting". The benifit being after the process the dry ice simply changes to CO2 and dissappears... Hmmmm
WIKI SAYS...
WIKI SAYS...
We're slowly integrating that process into our cleaning methods at my employer as well.
