Best carbs for a cl360..
Love the VM30's on the 360. needle one up from stock and I think I have 125 mains in mine, not exactly sure though. that is with pods and an almost open 2-2 exhaust.
Thanks for the reply!Does it rev properly?With the stock carb it just doesn't work for me!it overfuels and runs like shit..What else do you need to run those two carbs?
Cv carbs are near impossible to tune with pods and modified exhaust. The VM30's are easy to tune and the thing goes like stink. Noticeable difference in performance.
I don't have any problems getting stock carbs to work on CB360's with K&N filters and various exhaust set ups ;)
Re: Re: Best carbs for a cl360..
With shitty pods, yes. CV carb tuning is relatively simple.
You've obviously never done Honda 3 jet carbs then ;)
Re: Re: Re: Best carbs for a cl360..
"Relatively". :) I should have said that the CV carbs on the CB450 got significantly easier to tune after I bought real air filters. Did go through some plug tho...
To further clarify: don't use EMGO pods with Honda 3-jet Keihin carbs. :)
Guys, there is no question that Mikuni round slides are a huge performance boost for the 360. If you have the scratch, ditch the CV's and put some pull in your pony!!
Further response - wouldn't have been able to do it without dozens of hours' reading your, 66sprint and Bill Lane's posts.
I can't remember working on modified 450 carbs?
I'm pretty sure it was stock carbs/ air box or AMAL carbs (yep, that long ago ;) )
they probably need the same modifications as 350 and 360
Quick question, guys. I also am running the stock CV carburetors on my 360, and I am also looking to upgrade to the Mikuni 30mm. In my experience the Mikuni carburetors have a slightly different throttle cable setup. Any major modifications that need to be made in regards to the hand controls or the intake boots, or does everything just match up out of the box?
Just noticed your in Nederlands, you should be able to find RD350, RD350LC or RD350YPVS carbs far cheaper than new VM30's
They work real well and are even easier to tune than VM30's (smaller venturi, 'correct' style emulsion tubes)
The RD's take in a lot more air than a 360 ;D
