Best cb450 suspension
thearcticsea
What's up dooods.
So I'm about to start tearing apart my forks on the cb450 and was planning to rebuild them. Then i started wondering if i should put in some progressive springs and a better pair of rear shocks.
So I'm jw if anyones put some better suspension on their 450 and if I can get some links to a place to buy?
Thanks guys
i couldnt finds a set of progressive springs for the 450 front end, but i know that a set of xs650 springs should fit in them (just measure what you have and compare to mikesxs). that way you get new, uprated springs. imho "progressive" is more of a gimick and is only really comfy for cruising around... feels weird in the corners.
best thing you can do though is new seals (also i think they make some 'low friction' seals... theres a guy on ebay named les (barker?) who sells them) and getting some valve emulators. the ones from mikes xs are CHEAP and work just as good as the racetech ones i hear.
I've got an email into mikesxs right now. I'll let you know what happens. Turns out i need new legs i hunk. Mine are all rusted where they slide through the triple trees.
