Best place for new points/condensor
iSack1L
The left cylinder on my 350 twin seems to be shutting down at low idle (at least that's what mechanic thinks). New points and condensor? Best place to buy?
I'd invest the money instead in an electronic ignition if you're going to be replacing points and condensers. I don't think DYNA makes one specifically, but other models can be fitted, if I'm correct. DrJ might have more to say about that.
That being said, it might not solve your problem. What has already been done/checked?
Carbs sonic bath and rebuilt by Honda. Only been ridden a few times since then, but there was never any gas left in them during long storage. Compression tested. That's about it. The technician was an older guy who I was assured would know anything and he was positive that I needed new points and condensor. He fiddled with the stop and mixture screws a bit, but could hear the left cylinder shutting down at very low idle. I can ride it fine, but have to be sure to give it some gas while at stop lights, etc. What is the benefit of the electric ignition? And would this require mods to the rest of the electrics?
Switching over to an electronic ignition means NEVER having to adjust, clean, or worry about the points again. I believe once you set the timing, it never really needs adjusted again either (don't quote me on that one though).
I read somewhere online a long time ago that condensors never actually wear out - it's just common practice to replace them along with the points.
Because of my wedding and honeymoon in 3 weeks I don't have a tremendous amount of coin to throw around. I'll probably just stick with the condensor and points setup. Could my problem just be a matter of points needing cleaned and adjusted? How often ought thus be done?
Your manual will tell you when you should check/adjust, but honestly I and some guys I know do it all the time. At least once a week. It only takes a second and can save ya a headache or two.
