i just got some new clubman handlebars and need to make 3 holes/slots in them for the wires. What would be the best tool for this? a dremel or should i just drill a bunch of holes with a drill bit?
a drill is the best tool for making holes. if you need to make a slot, drill two holes as the ends of the slots, and then use a cut off wheel to cut off the gap between them.
I find a spoon works pretty good. ;D Just kidding yes a good sharp drill bit is your best bet. Take and center punch the spot you want to drill and start with a small bit and work your way up. just be careful the bit may want to walk and small ones have a tendency to break.
When I drilled mine, I used a dremel with a cut off tool to make a 1/8" diameter "pocket" instead of using a center punch. Then drilled a small hole as a guide, got the size drill bit I needed and made the proper sized hole. But once I drilled the hole straight down and through the wall, I tilted the drill bit TOWARDS the centerline of the bike leaving an angled hole in the bars. Made routing wires much easier
And remember to measure twice and cut once. club man can be tricky cause if you drill your holes wrong they can poke out from under the controls or they can sit uneven on the bar, wouldnt want to ruin your new bars. best of luck man
