Bicycle speedo questions.
CB360ty
Active Member
So I have heard a few people on here have used a bicycle speedo to replace there regular tach but from what I have read the bicycle speedo has to hook up some how with the disc brakes. My problem is my bike only has drums front and rear so how would i hook up the speedo with drums?
and also if anyone has any particular suggestions with what exact brand and model speedo to get please tell me.
Thanks!
-Ty
In case nobody else answers this - I think it was T71Ford that has used one in the past. And Rocan should know for sure..... it's what he does for a living!
Theory behind 99% of bicyce speedos is that they use a stationary sensor to pick up blips created by a rotating magnet. These 'blips' are then analysed by the internal algorithms to give you your speed. YOu do need to put in your wheel circumference first, though.
This can be found out by wheeling the bike 10 wheel rotations (use the valve to mark rotations), measuring the distance and dividing by ten. Thats your accurate circumference. Alternatively, you could just run a tape around the tyre - make sure its in the middle, though!
As the drum doesn't rotate, I'd fix the rotating magnet to the spoke (as on a bicycle) and the sensor to the fork leg. You may need to space out the sensor with a rubber block so it is close enough to sense the magnet.
If the magnet doesn't want to clip to the spoke with its stock attachment, use araldite. I generally fix the sensor to the fork with clipties.
Cheers - boingk
Do you guys know of any that have a backlit screen that stays on all the time?
and thanks for the info as well.
-Ty
-Ty
None that I know of.......get an Acewell ;)
mofos are all wrong!
wheel diameter is what you need; most speedos are measured in MM when you first set them up. measure including tire diameter.
attach the sensor to your spokes... closer to the rim the better (just a bit more accurate). might be tricky to get the correct clearance; they need to be pretty close.
if you want a clean system, wireless ones are available. cateye are the best on the market... knog makes a simple one that is wireless and has a nice universal mount system.
knog is baclkit as well as some of the cateye systems.
Maybe new ones are different but all that I've used use circumference.
As boingk says, measuring actual circumference is most accurate, tyre tends to 'flatten' more on motorcycle as it's not running at 120+psi so 'rolling radius' is smaller than measured/nominal radius.
10 revolutions is going to be 60~70 ft or more?
PJ
So are they backlit all the time or do you have to push a button? Pretty useless on a motorbike if you have to push a button.
if i remember, backlit all the time. might depend on model though.
the wireless ones have a battery in the sensor and in the speedo itself. i just set one up an hour ago. super easy. attach with zip ties to fork, then a magnet screws onto spoke.
As long as you measure the tire correctly then yea they are pretty damn accurate. I used to work in a bike shop about 5 or 6 years ago and set up quite a few speedos. Very easy! I thought they were always measured in circumference...but its been a while. If so...an easy way to measure circumference is make a mark on the tire where it meets the ground...mark the floor in the same spot. Roll bike forward til the mark hits the ground again and measure. TADA! Circumference.
Yeah, I've only used circumference on the speedos I've used.
Anywho, you could get around the lighting problem by rigging a single white led light to your battery and mounting it to the handlebars via a piece of flat metal and a hose clamp. Bend the metal so the LED points at the speedo and illuminates it, without getting in the way of your viewing line. Put a switch on the wire and simply turn the LED on to illuminate your speedo. Alternatively, you could wire it into the headlamp switch...but I wouldn't do that for what will probably end up being a temporary solution.
Cheers - boingk
just thought about it...
it is circumference. i thought it was diameter because you look in the book using diameter to find the number (in mm) to enter into the computer.
