johnson_steve
Ok so some times when I hit this big bump I can hear the tire rub on the crossmember that holds the battery tray.
(That's not actually a picture of the crossmember. I need to update my photobucket account. the one in the picture never rubs there is a second one about 3 or 4" forward and 3/4" lower then the one at the back of the frame.)
This thing is small angle iron welded to the frame rails and it supports an aluminum tray that also bolts between the seat and the seat crossmember where the rear splash guard used to attach. I only notice it at 1 intersection and only if I hit the bump hard enough. I cant really move the thing as I already made the battery tray, seat and hump. My rear shocks have 5 settings on them could this help? or is there something like the opposite of lowering blocks?
I'm only worried about this because I assume it could get much worse if I add the weight of a passenger back there. I'm delaying the purchase of new tires which I really need till this is sorted out for fear that I will destroy a brand new tire. any advice?
