Bike checks for bike that's not running.
Heartbreak kid
A friend of mine recently was given a cb750a for free. Not my first choice but he would like to get it running. The bike is complete except for carbs from the previous owner which were removed for cleaning then lost.
I'm trying to figure out the most I can about the condition and how worthwhile this project is before the new carbs are purchased. What are some of the ways I can check this?
FIRST - Check compression
Make sure your compression is within 5 - 10% between all the cylinders. THIS IS THE MOST IMPORTANT THING TO CHECK FIRST
rebuilding an engine can be very expensive and take a lot of time.
Next you want to check spark
Grab an extra spark plug for your bike, or pull the old ones out, hook up the spark plug like normal, except outside the bike.
next
Hook up a good battery and turn the ignition on. Kick or push the electric starter on the bike. While holding the cable with your spark plug in it near the motor or frame. Something for it to ground to.
Make sure that there is a thick blue spark coming from all of the wires.
Now if your compression is good, and your spark is also good, chances are if you put some new carbs on it, it will run. Take your time, do these checks right. If things are not working out so good, bad compression/bad spark. Come back here and ask questions. Anybody here can help you to isolate or at least run through a check list of problems.
On top of what was said above (excellent) give her a squirt of lube down each sparkplug hole. Whether its engine oil, ATF, or pentrating oil (not WD-40) a little lube will help rings free up and keep you from scoring the dry cylinders while performing your tests.
Try the shift pattern while rocking the back wheel, should hit all the gears up and back down.
