Bike cutting out a low RPM
PancakeShake
So the past few days at low RPM's, like when pulling out of a stop, my bike sputters a little bit. Today it got really bad and I had to pull over.
When I did, I found my positive lead to the battery loose. Figured that was the problem, but when I was pulling into my driveway it started doing it again.
When I let it sit and idle it was sputtering alot.
It seems like it could be an electrical or a carb problem, 50/50
I have been running pods and I have a dirt road, so should I take apart the carbs and give em a good cleaning, maybe that would help?
Any input would be great.
P.S. I have been blowing headlights too, think that was just because of my positive lead being loose?
Cutting out at ONLY low rpm's? Sounds like a carb problem (as mentioned above). I would look more at your floats though - sticking, sinking, etc. Could be a pilot jet clogged I suppose.
just pulled and cleaned carbs, seemed better, then went back to sputtering.
Im thinking plugs now.
And yeah I rejetted it, ran 1500 miles with the setup with no problems tho.
Now that you mention it, I had a problem before with a weak spark plug-to-spark plug boot before that acted similar. It was almost like there wasn't enough current to get thru the weak connection. I think I cut off the 1/4" end of the plug wires, added new boots, and it worked again.
