So, I hate for this to be my first post (been lurking for a long time), but here's my problem:
First off, the bike is a stock 1971 CB450 on which everything worked mechanically and electrical wise.
I decided to try some clubman type bars, so I pulled the switches and controls from the factory bars. Installed the clubmans and controls back onto the bike, started it, let it idle to warm up, gave it a bit of gas at which point the tach/speedo lights lit up crazy bright and went out (not the neutral/turn signal indicator lights however). Later I noticed the taillight (the "low" light, not the bright light that comes on when you apply the brakes) also had burned out. I don't recall if this happened when I had the headlight switched on or not.
At this point the bike would run, idle and rev just fine with and without the headlight on.
After looking through a wiring diagram I determined that the gauge lights and that low brake light were on the same "circuit" (not sure if that's the correct term). Brown/white wires from the tach/speedo go to the light switch as well as the ignition switch (TL1), from the ignition switch (TL2) a brown wire runs to the "low" taillight. So I dug through the wiring and found the Br/W and G wire at the speedo light socket exposed and poorly wrapped up by the previous owner.
I unplugged the tach/speedo lights from the main harness within the headlight bucket, replaced the taillight bulb with a new one and started the bike. Now for some reason, with the light switch OFF, the taillight comes on as soon as the bike is started and will dim and brighten as the engine is revved. I flipped the light switch to the L and H positions and give the throttle a healthy rev and the engine dies almost immediately.
I opened up the start/kill/headlight switch and everything seems in order there, although there was a repair made to the kill switch wires. Headlight switch internals and wiring looked unmolested.
Anyone have any suggestions on what to check next? Could there be an issue with my ignition switch? I'm no expert when it comes to electrical gremlins but I'm not entirely useless. I completely rewired a 1967 Plymouth Valiant from scratch using only a wiring diagram, everything worked fine for years afterwards.
Help...
Help...
