Gedigedi
Hi All,
So after tinkering with my bike for the last 2 years I have decided I should check my valves.
My bike has been backfiring through the carbs and exhaust prior to adjustment. At night I could even see a small blue flame shoot out once in a while or a good pop through my carbs.
I adjusted for .003 for Exhaust and .002 for Intake as recommended and did my adjustments on the compression stroke ( Left on LT and T on right).
Prior to valve adjustment, I tensioned the cam chain also ( seems to have quieted the bike a bit).
The carbs have been adjusted and modded my PJ himself and I won't be touching them or looking for problems in there. After adjusting my valves I also replaced the spark plugs but did not have a gauge to set the gaps for them ( Is this necessary?)
Once I was finished I took the bike out for a ride and noticed the bike was running way way worse than before adjustment and the backfiring through the exhaust increased x10 and way louder! One odd thing that I am now able to idle my bike at much lower RPMS.
I am assuming that I need to reset my points ignition and maybe check for sticky exhaust valves?
Can anyone suggest some other things I could check ? Exhaust Air Leak ? Did I mess up my valve adjustment?
Thank you,
- Gedi
Thank you,
- Gedi
