Bike woes, HELP PLEASE
Dingo
peace and grease
I changed the name of the thread, but thanks again!
It's been about a week since I've received my bike from the shop, allegedly it received a tune up (new filters, new plugs, got a leak fixed, fixed the wiring, new o-rings on the intake side) any way I took the bike out yesterday and it was running like a champ, headed out to get new shocks, and didn't have a single problem, today I reattached the fork brace and was going to take it out and well, it sucked.
Started the bike to le it warm up and it wouldn't idle, after a few tries the battery seemed flat so I swapped it and bike fired, got it to idle, but it was kind of high around 2K, but that was after fiddling with the idle screw a bit, since it would die out if it went lower than 1.2k.
After about 10 minutes of fiddling with it and warm up, I took it to the streets, the first few hundred feet seemed normal, but then it died, tried to use de e-start, not even a click, tried to kick it and nothing, gave it a second go with the e-start and it came back to life, so I headed back home, and it died again outside my garage door, I almost dropped it, but I saved it about 10° before it touched ground, took back to the garage and no power, started it the bike once more, left it to idle for about 10 minutes and it can rev normalish, but in gear, no power once again, cylinders on the left side seem to be hotter than those on the right side, but I think that might be due to bike being on the side stand (it doesn't have a center stand).
Also gas in the tank is about 2 months old, I'm pretty sure that has to contribute also.
Currently I'm charging the battery. After those 10 minutes idling I stopped the engine and it wouldn't fire back on after that.
So to recap: 2 month old gas in the tank, no power after 3k when in gear, left bank is hotter than the right bank. Leaned almost to the point of dropping, high idle, no restart after 10 minutes idling. Bike's a CB400f
I'm fearing It might clogged jets and something else.
Help!
Re: Bike decided it would go out to play :'(
Don't take it to a shop. The only way you'll know what's wrong or right is to do it yourself.
You're not firing on all cylinders, obviously. Check the big 3: compression, ,spark, and gas. Get a compression tester from Auto Zone. Check that the plugs are wet, and that they do get a good spark. And gas is cheap......when in doubt throw it out.
If you're not getting power above 3k, it's most likely electrical or fuel related. Drop the float bowls, pull the jets out, and clean them.
Probably going to need carbs off or cleaning.
Modern 'fuel' has a real short 'shelf life', doubtful if draining tank and carbs will be enough to clear pilot jets
I was actually planning on using all of the gas in tank and then doing and electrolytic rust removal before painting the bike, So I guess I'll just have to do that earlier than I thought, and drop the carbs at the same time for some cleaning.
Now that you guys mention an electric gremlin, the bike had a pretty messed up wiring and is running a 100w headlamp, that drains the battery fastish, and today noticed that the battery was kind of down on power.
So change of plans, seems like I'll be starting a new project thread.
Re: Bike decided it wouldn't go out to play :'(
100w headlight is just dumb on 400f, the generator only puts out about 110w
If it's H4 bulb, fit a 35w, it will be brighter than an underpowered 100w
reading around the sohc4 forum I think I found the solution to my problems.
1) I have a crappy battery, so that thing's recharging for the night.
2) I'm getting fuel starvation on the right wide of the engine, that's because there's supposed to be 2 fuel lines coming out from the petcock and I have just 1 on the petcock connected to one of the fuel intakes, and the other 2 are capped of.
Well I spent al the afternoon wrenching on the bike with the help of a buddy of mine.
First thing noticed, air box only had clamps on the outer 2 carbs, the centre ones didn't, so they were runing without filters.
We connected the carbs to the air box and put some clamps on them.
Then I drained the carbs, and since the o-rings where shot changed them.
The plugs where black as night, but not oily. We also cleaned those.
We got the bike running again, although the idle was high, we played with that a while and got it to around 1.5 k rpm, but while it was idling and heating up it jump up and down a bit.
After a good 5-10 minutes of warming, we started revving it, and it seemed normal, all 4 exhaust pipes where about the same temperature also.
We put the bike back together took it out on the street and once in gear it died again. Restart and the bike wouldn't pass 3k on the rpms, and no power.
The cylinder on the far left wasn't as hot as the other 3.
I really have no idea what to do next.
BTW, plugs are new, the carbs have been recently cleaned (less then a week ago).
Assuming your CB400F has a stock airbox, filter, main jet and pilots, headers and exhaust this sounds like your idle circuit is clogged. CB400F have small carbs and even smaller idle jet circuits and can plug easily. Pull the carbs and thoroughly and meticulously clean them again, check the float levels and report what number main and idle jet you have. 75 main jets and 40 idle jets are stock. Float height should be 21 mm. Carefully run a small diameter guitar string into the idle circuit, spray with carb cleaner until the circuit is clear. Hit it with compressed air to blow it dry. Carefully clean your idle jets with carb cleaner and compressed air. You should be able to see through the tiny orifice when done. Drain your tank, clean it well, use fresh gas and install an inline fuel filter ($3.00). From experience, CB400F carbs are very sensitive to the tiniest bit of dirt, rust etc in the fuel.
Secondly, a new battery is not necessarily a good battery. A fully charged battery should read above 12.25 volts after the headlight has been on for one minute (when bike is not running). If not, the battery is not holding a proper charge. I find most cheap electrolyte batteries will not last two years.
As mentioned, clean the carbs and plugs, get her running, set the idle and then do a compression test. You want even compression across all four cylinders. You do not need such a high wattage headlight.
Ensure you do not have any vacuum leaks on your intake system and then synchronize your carbs. CB400F carbs take quite a bit of fettling to get them right, but once they are, they run like Swiss watches. Read my CB400F build thread for my carb issues. I chased the dreaded "idle hang" on my last CB400F for more hours than I can say and ultimately solved the problem with new OEM Honda carb parts. The needle and emulsion tubes wear over time and and cause issues with the idle circuit. DO NOT use after market carb kits (Keyster and K &L) because they use softer brass, are of different design, out of spec and cause lots of frustration.
I will send you a CB400F carb rebuild manual with lots of images. Good luck and post your results.
The pilot jets have about a 0.0157" hole (40 jet number)
That's not quite sixteen thousandths of an inch
DON'T enlarge it by using a drill bit or poking with steel wire (unless you have a number 79 drill bit?)
Use a single strand of copper wire from old harness to make sure they are clean (really clean, oxidation inside hole will reduce diameter)
Thanks for the input,
I've been wrenching most of the weekend with the bike, yesterday I got the left side firing, but not the right side, checked the plugs and they were sooty, black and dry, I think they might be to hot for the engine, but those where only the ones in the firing side, the ones on the right side where clean, so I swapped them around and got the centre right cylinder firing. Left it alone for a while and the bike stuttered and kind of run on 3 of the 4 pots, the far left not firing.
So to recap, all 4 cylinders fire, but not at the same time.
Also my coil leads are in a sorry state, and the spark is weak, the honda shop did a tune up on the bike, and allegedly cleaned the carbs, I did see them off the bike without the float bowls during one visit. The shop installed a relay with a 10 amp fuse, I'm guessing that was done so the coils get more power.
Even if the battery isn't in top condition I keep it charged, I have now also changed the headlight to a 35w unit.
Took off the petcock and it had rust flakes sitting inside.
On the sohc4 forum they recommended doing the 3000 mile tune up and then chasing the bugs from there, but a tune has already been performed by the honda shop.
What should I do next? I'm planning on replacing the coil leads and plug caps, also changing the plugs to a colder unit.
I think I might also try a hand with electrolysis to clean the tank.
I would be sure your points are gapped and timed correctly and clean. Next, be sure all connections from your points to coils to plugs are clean, tight and have continuity.
