Black magic led
Texasstar
Can't is a four letter dirty word
So our LED bleeds through our dash bulb and the right blinks but when you switch it to left everything flashes. I understand why this is happening but why isn't it consistent and flash on both left and right? Need some help from the magician. Oh and positive should really be called negative and negative positive...thanks to Ben
After fixing our blinker light in our tach we tackled the blinker wiring in our new LED tailight. We installed a new electronic flasher. Now the right blinker works but when you switch to the left blinker they all flash. So we tore into the wiring with a test light. The LEDs don't have as much resistance as the incandescent so bleed through is happening on the dash light because it is wired like...see diagram. So diodes need to be placed so the bleeding stops and we can regain the light in the tach. If you unplug the light in the tach voila you get both blinkers. But what I am asking is why doesn't both flash when you use the blinker both left and right....there must be more resistance on the right than the left. More than likely we will use the diode method http://faq.ninja250.org/wiki/My_LED_turn_signals_don't_work_right#LED_method
And be done with it.
I am having to explain to my son that because Ben Franklin called positive and negative wrong we now have confusion how electrons actually work. What we call positive on our battery should be called negative because the electrons flow from the negative to the positive...this "convention" or wrong labling by old Ben is the source of much confusion when understanding how direct current works. The circuit is a "pull and a push" as far as electrons go according to my wife. It would of been less confusing if Ben knew what an electron was and knew how to label it correctly...:) when we short a wire we are slamming on the brakes so to speak of the electrons and we blow the fuse or fry something. I suppose since that supercollider found that quark in France all of what we consider convention is about to change again...:)
http://tech.bareasschoppers.com/electrical/vtx-1800c-diode-fix/
Black magic led
I'm guessing you have an LED indicator bulb? If so, one direction works fine and the other doesn't (both flash) because the current can bleed through as you say only in one direction.
An LED is like a one way valve. Current can only flow in one direction. It is a diode, a light emitting diode.
END OF LINE
Re: Black magic led
END OF LINE
the way you put it makes it that much clearer! Yes we have an integrated led tail light and blinkers...and it is wired wrong.
She is a flash dancer...tell us what you think we moved the electronic relay to the end of the circuit on the tail light and put it on the ground. We think it will help us bee seen more keeping our gal from being banged in the rear by someone else? What do you think?
http://youtu.be/PqSPrp0WaYY
