Blowing fuse on CB360
AzHonda
Coast to Coast
I am just about done with this build and I have everything hooked up and everything (but the electric start) has been working. All of the sudden I am blowing the 15 amp fuse. Not everytime I turn the ignition on but maybe 8 out of 10 times. After I first got the wiring all back on the bike and the after market headlight/horn switched figured out and running, I literally would have the bike in the "on" position testing things out for 5-10 minutes at a time.......no problems. Now, blowing the main fuse. And also, now my headlight wont come on. Tested another headlight so I don't think it is the bulb. Havn't put a test light up to it yet to check for power.
I would think that it has to be something grounding out?
Any ideas?
Something is grounding out. Get a meter with a continuity function. Start check for continuity to ground for different sections of wire along the circuit that is blowing the fuse. Once you find the section with continuity to ground, you know about where you're grounding. A common area is the wiring inside your switches grounding to the handlebars.
Are you running turn signals? That relay has a certain way its set up, if you hook the wrong wires up it will blow fuses all day. Check your wiring diagram.
DUDE!! you may have just hit it! Guess what I just did right before I turned the bike on? Put in a new relay. The thing is.....it didn't blow the fuse immediatly and then other times it did. Would that also be why I lost my headlight though?
Out of fuses now and will pick more up tomorrow and switch the wires on the relay. I hope it is that easy. I should have been paying attention to my manuel.....
Welp! Problem fixed. Had the wires switched on the relay. The headlight issue was a poor connection on my end. All fixed.
Thanks for the input guys. Saved me a big headache!
