Blown my fuse....
Druro
Noel... stay outta my profile... wanker.
So, I've been working on my little CB360, but I've run into a problem with my main power fuse.
I've been running and testing the bike in my garage without a problem, however on a quick round the block run, I blew the main power fuse (luckly, I was about 10 ft from my driveway).
What would cause this? The bike's wiring has been modified as the starter had been pulled (along with associated wiring).
Could this be a problem with the rectifier?
Any thoughts would be great.
Without a doubt, theres a short somewhere.
What happened last before the fuse blew? ie... Did you turn the handlebars?, flick on the turn signal? etc...etc...?
I'd start right where Leon said, make sure no wires are grounding when you turn bars, compress suspension, etc.
Also, take a look at the clips in the fuse box. I'm assuming that your bike uses the old style barrel fuses held in place with brass clips right?
I had similar issues with my 77 kz650 and it was nothing to do with bad wires. My fuse clips on my primary had corroded enough that they were causing resistance on the circuit and my fuses were heating up double quick and blowing ferociously. I took my dremel with a wire brush attachment on low speed and cleaned the clips up until they were shiny, put everything back together and never had a problem again.
Even if you find that there is a wire problem, cleaning up those fuse connections can't hurt anyway.
Good luck!!
Good luck!!
Thanks Guys.
I can cover one point right away. The fuse clips are perfect... i mean they seriously look factory new.
In talking to Noel, I think that it's wires in and around the headlight bucket, as they are a BIT of a mess.
Are your control wires run inside the bars or outside (can't remember if you're running clipons or clubmans or stock bars)?
The wires are outside the bars (modified). I believe that these controls were designed to run inside the bars, however as the bike came with clubmans, the controls are modified to run the cables outside the bars.
Were the housings on the controls reemd out to let the wires run without pinching or binding? That would be an ideal spot for a hot wire to get pinched and grounded on the bars.
