BMW 1974 R90/6 Restore (for now)
Re: BMW 1974 R90/6 Restore (for now)
120$ each total of $300 shipped, the guy had them listed for $200 each plus shipping obo so I offered 120 and he took it.
Send from my Razr Maxx HD
End time: Nov 21, 2012 8:04:47 PM
Item: FRONT WHEEL TIRE HUB RIM 1974 74 BMW R90/6 900 R90 R 90
URL: http://pages.ebay.com/motors/link/?nav=item.view&id=140806107589
Alt URL: http://www.ebay.com/itm/FRONT-WHEEL-TIRE-HUB-RIM-1974-74-BMW-R90-6-900-R90-R-90-/140806107589
(Sent from eBay Mobile for Android)
I didn't get them yet but I was planning on replacing them anyway
New parts
"New" parts
Sent from my DROID RAZR HD using Tapatalk 2
I got the headlight today and even though it's 9° today I installed it on my lunch break
My brother and I got the petcocks rebuilt and the carbs as well
I pulled the front spoked rim off and test fit the lester mag. I think that the tires that came on the lesters are to big, the wheel won't fit between the fender mounting bracket.
Deflate the tire a bit - that's pretty typical on some bikes. What are the tire sizes?
Of course if the Lesters don't work out for you.... :D
Re: Re: BMW 1974 R90/6 Restore (for now)
Lol. The stock spoked rims are bent, I'll probably put the hubs on ebay or advridr
If anyone is looking for a front and rear hub i have them for sale
So i just found out that the lester mag bering diameter is much smaller than the stock one :-(
I can just swap the innards correct? (I'll need new berings of course)
Usually a bearing swap is all that's needed.
You may have some fun with spacers if the stockers aren't quite right for the Lesters.
See if you can see any numbers on the bearings that are currently in the Lesters. THat will tell you the OD of the bearings as well as the width.
THen source new bearings with the old OD and Width, but the correct ID for the axle.
BMW wheel bearings are odd beasts, at least compared to most of what we have.
They're tapered bearings, not sealed roller bearings that just pop in and out as a single unit. There are a whole host of spacers and shims in there too.
To get the bearings out of a BMW hub, you need to put the axle on the hub, with some spacers so you can create pre-load on the bearings. Then you have to heat the hub to around 250 degrees and drive the entire stack out as one piece.
When I decided to replace mine (I was relacing the rims, replacing tires etc.) I sent my hubs to Woody's Wheel Works in Colorado. They do a swap and replace the BMW bearing stack with a more typical set of sealed bearings and simple spacers. Also bead blast and clear coat the hubs - look like new when they come back.
The Lesters might have a more simple bearing setup than the BMW's. Look into it a bit before trying to remove them from the wheels. Got a pic of the Lesters close up?
The top pic is the lester wheel
The threaded part of the axl fits.. Lol
I'd go with sealed bearing
Thanks for the info!
Take that retaining ring/dome off the front Lester. If it has that, which looks identical to the BMW front hub, then it's likely the same internals. If someone in the past swapped out the bearing for a smaller axle, then perhaps the spacers inside are larger diameter and will work with your axles if you swap back to the right size bearing. However, if the wheels were setup for a smaller axle in the first place, the internal spacers will be too small as well.
