BMW R80
  • Thread starter Thread starter sam
  • Start date Start date
S
sam
Guest
A fair bit of progress has been made recently, I'll do my best to let the pictures do the talking.
The original bike as I got it:
Close-ups in the original state:
Removed a lot of the clutter:
Polishing:
Comparing polished to unpolished fins:
All done on one side:
Carb tops(this was the first thing I polished, so it was a pretty poor job):
Switches:
Original state:
Half way done:
Done!:
Okay, it's the other side, but same result!
Spent a couple of days figuring out the lights, and this was the result:
All lights at the moment seem to working, except the oil pressure light. I've got a replacement piece of wiring, so it's only when that doesn't work that I'll worry.
What i'll be using for moving the foot controls and pegs further back:
Here's the bike running, probably the second time the engine fired in the past 2 odd years.
http://www.youtube.com/watch?v=O5nNKuiQxt0
Did those bings have a spring above the needle valve? The book says that some did not use them and mine do not, but look like they should. They appear to be the same as yours. (73 r75/5)
Actually, I haven't needed to take the carbs apart yet, as the only things I've had to do were in the float bowl area or outside(next step is a choke cable eliminator). This video was really good for me when I was figuring out what I need to look out for when I take parts off of the carburetor:
http://www.youtube.com/watch?v=Q__LkgoaGGk
That bike looks like someone pulled it through the ringer good and proper. I am sure you will restore some respectability into the old girl. Good luck
I would love to get an old BMW like this.. Looking great man! Love those bikes. What cc is the r80?
Sent from my Galaxy Nexus using Tapatalk 2
A small amount of progress has been made recently, as I sold my other bike(2009 Ninja 250) and had some extra money.
So far I've bought and had delivered:
  • Acewell 2852
  • Clevis pin for the rear brake rod
  • New headlight fittings
  • New valve covers - 'peanut covers'
  • Rear brake switch
  • New oil pressure switch
  • New wiring connectors
Just in the past week, and have been installing them as they arrive.
Still to arrive I've got:
  • Pair of cheap bar end mirrors that I'll use to get it road legal
  • Carburetor rebuild kit & cylinder gaskets
  • Pair of BMW cufflinks that I'm going to use as choke/enricher eliminators
Enough lists, onto the progress itself.
Polished and painted engine:
Headlight lens after juggling it with my foot:
Acewell 2852 installed:
All the lights worked first attempt! The small red light below is a charge/gen light. BMW has a charge light that isn't compatible with Acewell. As luck would have it, the cheapest round gauge Acewell I could find had none of the lights I didn't need, and had all the lights I did.
More photos of the bike as it stands:
As it is, the tank has been primed in the matte yellow and will be rattle canned a gloss black, both because I have some spare cans that I never used, and because I couldn't find a tank so far, so I'm hoping to make do with what I have.
The bike runs a little rich on the right side for now. So much so, that there is a considerable different in temperature between the two cylinders when it does run. Once the carburetor rebuild kit arrives I'll retest the engine to see if it is still uneven, but for now that is the only obstacle between the bike and road legality.
What did you use to polish the head fins! I haven't got to making mine look pretty but, what you did looks great!
Sand paper. Lots and lots of sand paper. Each side probably took about 8 hours. I'd recommend finding something that makes it easier, what I did was bordering on insanity.
Small update.
Cleaned the carbs by boiling in diluted acid(lemon juice/vinegar), then boiling in plain water, soaking in hot water for a couple of hours(not so hot by the end), and then finally rubbing the entire piece with a cotton cloth.
Left is cleaned, right is dirty, in case it isn't obvious.
Reverse for this one
The moisture is in the corner because I had started to boil it for all of 20 seconds before I decided I should get some side by side photos to aid in comparison. The brass overflow has already discoloured, and the residual heat in the float bowl has evaporated most of the water in between photos.
Then I polished them a little and they came out looking great!
Then I had to install a new rear brake switch as my bike didn't come with one. They are required by law here if you want to get your bike road legal, so I have to install one.
Bought one of these:
No where to put it:
Found this at a marine shop, bent it to shape and drill the holes to fit the bolts I'll use:
All finished:
Just have to extend the wires on it now so it will reach the connector in the main harness.
Not sure if I'll keep it long term, but it will get me a warrant at least.
Looks great man! Nothing like clean carbs..
Though I'm not sure if you did them separately but if you used lemon juice AND vinegar at the same time you canceled one out. Vinegar is a base and lemon juice is an acid. I'm not a chemist so I dont know which one won the Litmus battle but probably the one that had the most liquid poured in. It would have been better had you done lemon juice boiled, then vinegar.. But I looked like after the mixture it still cleaned them up pretty well!
The bolt that came with the Acewell wasn't going to be easy to fit to the front rotor, so I had to come up with another idea. I had an old hard drive sitting in a laptop that was broken beyond belief, so I removed the magnets from it, as I thought they were a shape that would at least be easy to mount to a bold.
Hard drive:
Magnet(poor focus, sorry):
Installed:
And in the mail arrived my BMW cufflinks for the enricher/choke eliminators:
They are a little over 20mm wide.
I found some wire on the road whilst I was out running, so I'll use that to adapt them to the current choke.
Straightened out wire:
Polished one of my valve covers:
Compared to the unpolished cover:
Close-up:
Total time, probably close to 4 hours for this one cover. Fortunately just the 2 covers on this bike. I'll fit it tomorrow and get an updated engine shot then.
Also measured the valve clearances because, as mentioned above, I was having a few issues with one cylinder getting hotter than the other. Or, rather, one not heating up properly. Fortunately(or maybe unfortunately), they were all perfect in measurements, so I haven't found the cause of my woes. Still haven't tested out carburetors since rebuild and cleaning, though, so it's still very possible that that fixed it.
Okay, started it up today after fixing a few of the wire connections on the starter relay, and it started up perfectly. Only ran it with a float bowl's worth of gas, so it probably didn't get to warm up properly, but it sounded great, temperatures on either side were very much even, and the rev counter + speedo(rolled it down the driveway) worked perfectly.
Valve cover looks great on it, too!
Next step is install a set of mirrors, a few e-marked indicators, a number plate bracket, find a pair of fenders that will make do, a red reflector for the rear, and tidy up the wiring. After that, it should all be road legal. Once it's road legal, I can start to change the sub-frame, finish the rear sets, move the battery, etc, without worrying about some compliance nazi telling me it isn't safe.
Hi Sam,
I'm most likley going the acewell route. They sell a lead for the speedo that connects to the original cable drive, a kind of analogue to digital convertor I presume, have you seen them.
Aparrently the "gen light" issue can be sorted with some internal tinkering, its mentioned on page 8 of this thread http://www.advrider.com/forums/showthread.php?t=527749
Following your build! and wish I had you patience with sandpaper!!
Lawman said:
Hi Sam,
Ya know, I'm quite certain that I've read that entire thread twice. In jumbled order; but still twice as a whole. Some how I managed to completely miss that particular reply.
It would certainly have come in handy, although in hindsight I don't think I would have had the nerve to pry open and tinker with the speedo. Not when I live two weeks by post away, and Acewell still haven't replied to my email asking how to turn the low-level flashing fuel gauge off - for some reason they didn't include the option to turn it off via the menu on my gauge. It's a little over a week.
The red light I've got here is a two wire incandescent bulb that has one wire going to the main harness "gen" light, and the other to the (I'm going from memory here) blue/green negative that would have otherwise gone to the instrument cluster. I'm pretty sure it's the same method, but that guy on advrider just has a slightly prettier end result.
As far as cables go, I just installed the one that came in the box. I wouldn't mind having a cleaner speedo cable that goes to the transmission, but they are somewhat expensive for what they are, and that's not including whatever I get reamed in the arse with in the form of shipping.
This is what is looks like currently:
I think with a clean up in the form of some polishing and a little powder coating and it will all look great. Well, at least acceptable.
And as a small update, this is the plan for the choke/enricher eliminators. I'll probably drill a small hole through the choke cable "barrel" and run some strong wire through the hole and up to the BMW emblem. Not sure how to attach the two together just yet.
Naff or neat?
(Yes, I know CV carbs + pods are worthy of the death sentence. I needed to test if the engine worked properly(it did!) and I'm far too lazy to put the original airbox back on while testing, as it's incredibly cumbersome when compared to the pods, and the carb boots are a pita to put on properly.)
[/quote]
I'm undecided about the airbox, to be fair, leaving it on is not bad cosmetically, but then again the pods look good.
I ground off all the battery housing lugs to make me install the battery either where the airbox is or inderneath the gearbox.
I'm splashing out on a Shorai Lipo battery, much smaller and considerably lighter.
Like the cufflinks! very dapper.
Fired it up today, and aside from a temperamental starter relay(have to fiddle it around a little, do they slow die? or do they have a binary life? might just need to clean the terminals), it all worked great. Got a few funny looks taking a loud bike with no tank up the road 350 odd meters and back. Far enough to get up to 60km/h. Can't wait until I can take it for a ride on more than a float bowl's worth, it's just not far enough!
Tank has really had it. Fuel was leaking out, fuel lines might as well have been a glitter wand, added to the fact that it is riddled with almost as much bondo as dents means I really can't use it. I was hoping I might be able to use it for the initial inspection, and find another tank after that when one comes up locally for sale, but that just isn't going to happen.
Found a large sheet of 1mm stainless steel that I could use to fashion into a block off plate for the starter/airbox area, a rear cowl, and a battery tray. Stainless would save on polishing, which is always a plus. Also found a VN 1500 seat for sale, which I think I could cut up and recover in some brown leather that I got hold of.
Added a short sentence to a few of my local listings(eBay equivalent) asking if anyone had a BMW Monolever tank for sale, and if so to contact me. I didn't expect much but actually got a phone call a couple of days later from a guy who lived some ~100km away from me that had one in "average condition". He said it had been sitting on a shelf for a couple of years waiting for a project for it and had a couple of scratches, but that it should be good to use and that it actually held petrol. 8)
100km is pretty far away, but I had to drop my dad off at the airport today anyway, and as that's half way there and on the way, I figured I might as well pick it up in person. This guy had a HUGE amount of old airhead parts. Projects galore, too. What looked like a /2 being restored, a franken beamer - /6 frame, mono engine, /7 tank, /6 wheels, etc - that he was putting together with "parts lying around". And his pride and joy, an absolutely immaculate 1974 R90S. So many parts sitting on his shelves, too - old BMW fuel tanks, crank cases, frames, etc. Probably 6 or 7 bikes sitting on those shelves Apparently Airhead guys don't like to sell their parts, and instead prefer to barter in a closed circle/network keeping all the parts between a dozen or so guys.
Anyway, I picked up the tank for $200(budgeted for $400!)
And I'll take it on the road tomorrow. No road-workers on a Sunday, and less traffic = less chance of trouble with an unregistered bike.
