BMW R90/6 build
MrMister
DTT BOTM WINNER
I just bought an unfinished project. Going to need some pointers with the usd forks to make the rotors fit.
Nice. Looks like fun. As I said over on your other post, check out R90Xdesigns.com. Matt has an adapter for that hub that'll allow you to bolt up Ducati rotors.
Thanks for the info. I also found out that cognitomoto sell complete front kits and hubs to fit a lot of different forks. Id like like to keep the dual rotor setup.
You can do that, just use two of his adapter rings and two Ducati rotors. You'd probably have to come up w/ some kind of spacer or do some other machining work to get that all to mate up w/ your existing calipers, though. Who knows, you might luck out???
Update. I got a complete spoke wheel to fit the zx6r forks from cognitomoto during their blackfriday sale. Waiting for it to arrive. Went with 18" 2.50 rim to fit 100/90-18 Metzeler roadtec01. That width can fit 90/90 through 110/90.
Got these Brass spoke weights. Getting the tire seated was a pain. About 6” wouldn’t pop out of the center of the rim. I eventually had to use the air compressor to inflate to 70+ psi to pop the bead in place.
