Bolts and Helicoils!!
Tristan
OK here the scoop.
Last fall I was reassembling my valve cover and stripped a thread...considered buying some helicoil, but I was ridiculously broke at the time, so I just drilled it out and tapped it to 5/8-16. (the closest size tap I had)
After the fact I really regretted it, since it looks botched...with the big head and all.
So my question is...What size helicoil will fit within 5/8-16 so I can atleast reduce the size of the head (really don't feel like dealing with welding).
OR
This might sound ridiculous, but do small headed bolts exist??
Well, I don't know if the helicoil will work because I think the outside thread is a weird thread, (I think that is right) so you would actually have to go up a size anyways now that you drilled it out and made it larger. Maybe call your local auto store tomorrow and ask them. I guess I would just grind down the sides of the head on the bolt to match the other ones.
Just took my measurements...1.25 mm off each side...needs to be brought from 12.5mm to 10mm
Guess I'll wait till I can head over to my mom's house and use the bench grinder...man what I'd do for access to a bridgeport these days.
Yeah, too bad I wasn't into motorcycles when I went to college for tool and die, I could have made a ton of shit.
Youre telling me.
I cant believe that I just paid $75 for stationary clipons when I could of zipped out a few sets of adjustable ones on the cnc.
Sucks to pay top dollar for things that you know damn well you could make yourself if you only had the tools.
Tristan said:
OK here the scoop.
OR
You sure you tapped it 5/8"?
That's pretty huge for anything other than spark plug or rocker arm plug.
Your not going to find a direct helicoil fit.
Best thing to do is find a brass bolt same thread, locktite it in place, cut off flush with seating surface then tap it for correct size
If you tapped it 5/16", you'll have to go up a size and still make a thickwall insert
Your right about looks, always looks awful when an inch bolt is fitted in place of metric and you have others to compare it with
PJ
My bad, 5/16".
Big R is going to do me a favor and mill up the head so that it's th size of the other bolts.
Once the job is done, the head will only have a diameter of 2.6mm larger then the threads....Think I'll take a washer and ream it open to accommodate the weirdness.
I've considered drilling a bolt and redrilling like you mentioned, but I'm afraid that I
A. Wont be able to effectively remove the stub without damaging the surface around it.
B. Won't be able to drill it straight enough with a hand drill.
Did it all the time when I worked at the machine shop...but everything is easier with the right tools
