Red Fthr
"Man is born free, and he is everywhere in chains"
After ruining every pair of shoes and pants I own via leaky oil I decided to replace all the gaskets in my engine. I'm following the manual and was cruising through the procedure until I got to the bottom cylinder. It seems to be stuck...like really stuck...like cemented on kinda stuck. I've dumped PB Blaster all down in it as well as break cleaner in hopes of loosening any possible adhesives. No luck. I've broken two screw drivers trying to pry it off and chipped a fin or two trying to knock it loose. I've also put a 2x4 under the #13 screw hole (the last screw to unscrew in the manual on the back side where the cam chain tensor would be) and whacked it with a hammer. It split the 2x4 and knocked the engine off it's resting place and the cylinder didn't budge.
Can someone lay some wisdom on me? Any other chemical reactions I can try or any physics tricks I don't know about?
oh, and yes, every nut and bolt that can be undone is.
