Bought a 78 cb750 yesterday. carbs seem messed up?
shredutah2
The moto is clean and well taken care of for it's age, as far as I can tell, aesthetically speaking at least. The motor sounded strong before purchasing it, but after riding around after doing the deal, around the city for several hours with a passenger, the responsiveness started to decline to the point of a weird..uh..gurgling noise from what seemed to come from the carbs. It wouldn't start at all this morning although it was trying. I'm guessing from my very limited understanding on these matters, that this is because the previous owner installed pod filters and failed to re-jett accordingly or the adjustment screws need adjusting, or both? He said he had compensated for the pods and made the changes needed. Obviously not quite. Bummed out a bit. Help would be awesome!!
Could be jetted too rich on one or more of the circuits, and has fouled the plugs. You should pull the spark plugs out
and see how they look. The seller could have just popped some fresh plugs in there to show you that it runs, but in reality it's not tuned correctly. I don't think that jets for those Keihin PD carbs are the easiest things to come by, if I remember correctly. Anyhow, checking out your plugs is the best place to start to see how she's really running.
Jets are not that hard to find, I picked up a set of mains and slow jets off E-bay for my 78 CB750K fairly cheap. The slow jets are discontinued through the dealer, but the mains are still available but not cheap that way.
So, funny thing. I was in the process of taking the moto to a garage of a friends. At first the bike was running terribly, until I decided to switch to the reserve tank for some reason. The bike instantly performed better. There is plenty of gas in the main tank though. Non of the problems are showing themselves now. I'm stumped...
My bike has the same issue. It used to run ONLY on reserve, i pulled the tank, inspected it and replaced the petcock. Now it will run in the "ON" position until about half tank then i hafta switch to reserve. I cant explain it...
Plugged passage way in the petcock. Rebuild it or replace it and you should be good to go.
But does that really explain the gurgling noise coming from, what seems to me, the carbs? While running ok it'll do that when I twist the throttle back quickly. I was reading in a Clymer that there is some sort of pump in carb #2. Also, so I know, someone that knows the correct adjustments that should be made to these carbs once pods are added, can you give me the run down? I didn't do the mod. Guy who I bought it from did...
You are starving the carbs for fuel with a restriction on the main feed in the petcock. The gurgling niose is possibly an air void in the accelerator pump on carb 2 or a bad diaphram in the pump itself.
Looks like you were correct, Spoonz. Not only was the petcock and fuel line gunked up with god knows what, it was also in the tank. I'm guessing that shit passed through into carbs/engine. Worried now about the engine. I want to switch tanks out anyways so not gonna clean that. How much is resonable to spend on a tank?
Pull the bowls, clean them, replace the lines. Tank price will vary by condition, other members on here may have a few floating around.
