Rich is right about the coils getting hot when the points are closed and not having a place to discharge its energy. To give you an idea how it works, One side is positive, from battery or switch and the other side is points/condensor. The points act as a temporary ground when they close (basically completing a 12v circuit) and that is where/when the coils get their inital charge. The full charge comes when the condensor fires back at them when the ground becomes open (points open). When the points open the ground is lost instantly cutting off power to the coil and the magnetic fields inside the coil collapse. This collapse sends some 30,000 volts from the secondary winding in the coil to ground at the spark plug.
There is actually a little more science to it but I think this gives a pretty good idea how it works. At least this is my rough understanding ;D
Just so you know, Dyna recommends 5 ohm coils for any points system. The only time they recdommend the 3 is in a racing application where they will get hot. You can run the 3 ohms but there is a risk that you will burn up your points. If nothing else the life of the points will be greatly deminished.
If I understand it right A 3 ohm coil is measured on the primary side of the coil. Basically it allows higher voltage to flow to the points than than does the 5 ohm.
So you can add a ballast resistor in the line before the coil but dyna doesn't recommend it. Not sure how practical that would be on a motorcycle anyhow, but its probably been done. Radioshack resistors could also be used but they run the risk of shortened life due to heat. So maybe you could make a heat sink for the resistor. Or you could avoid all this and run the 5ohm coil, or just run the 3s and not worry about it ;D
With all this said I know a few guys run the 3 ohms on a points system in a non-race application, but I don't know what kind of life they are getting out of their points and condensors. Maybe they can chime in?
As far as mounting I cut the outsides of the factory bracket and used longer bolts to mount my Dyna coils. We are running universal accell wires from advance auto parts( (about $25). They are a 7mm wire made for a v-8 so there are 8 wires (lots of left overs to share with friends) Also, You can pick up a set of 8.8 mm universal fit from Jc whitney for a motorcycle for about the same price (a bettter wire) These are for a single or twin.
http://www.jcwhitney.com/88mm-universal-wire-sets/p2020919.jcwx?filterid=c52761j1
I hope this has been some help.
