bought! now a project!
Re: should i buy this bike?
Oh... And make sure that all your grounds are clean and connected. A bad ground can shut down the whole bike.
Okay so I went ahead and.charged the battery. Ill wait till tomorrow morning yo see it it'll start.
This cb350 still had the little tool kit haha
And the fuse still looks good I only saw one.
I think I'm going to go ahead and take the gas tank off and see the electrical. I just want to see signs of light lol
This is a good plan. Pull the tank. First check the electrics...check for spark. Go ahead and check compression.
Once you have both of those checked out, add some fuel to the equation and it "should" start.
Do yourself a solid and start a proper build thread as well. You're likely to get a lot more help if and when you get stuck that way. The 350 is super simple, bit to a first time builder/tinkerer... It's easy to get a little lost.
Thanks guys for the input! Is there a way this could get moved to build section?
I have to go wrap things up since its getting late. But here is hpe far I got!!!
Im getting seasick looking at upside down pics...fix that first!
So far I removed the tank, seat, chain guard, airbox, tool kit and fenders
To be continued another day. Lol I don't know what to do about electrical though. I want to get it to start working
So here's an update.
I charged the battery at 6amp 6v over night
When I replaced the battery into the cb350 I got lights, signal,and neutral light to work!
Here is the problem, so I put the key into first position and make sure its in neutral and click the electric start. All I hear is a humming. Does this mean the battery is not charged all the way?
What is the second position for on key ignition? When I turn it to second position all electric shuts off.
I'm guessing the process of starting the bike is first position key, hold in clutch, make sure in neutral, hold on the right or rear brake?
You don't need to hold the brake unless you just want to.
Take out the spark plugs and use the kicker to make sure the engine is free. In neutral, but do not pull in the clutch. If it won't kick through, fill the spark plug holes with automatic transmission fluid, wait a couple days to give it time to seep past the rings, and try kicking it again.
Humming could be just a stuck starter. Pull it and floor test it. Hook the hot lead of your charger to the battery cable lug on the starter, touch the ground lead to the starter housing. If it so much as twitches, starter is likely fine.
Be very cautious with that fuel tank. Decent condition stock paint is very hard to find these days. If you plan to run a different color scheme, get different tins and set your stock ones aside for safe keeping.
You know your bike is 12v right? Also, it WILL NOT start with under 13v at the battery.
The humming sounds like its from the middle part of bike by the battery.
Ill try the starter idea.
For the spark plug test do I pull out both spark plugs?
What does this test do? I mean I can kick it just fine. But its not starting with kicking.
You think the gas tank will be worth some money? It has some dents and some paint is peeling away, as well as rust ...
..........Be very cautious with that fuel tank. Decent condition stock paint is very hard to find these days. If you plan to run a different color scheme, get different tins and set your stock ones aside for safe keeping.
If it is free, change the plugs and check spark, and kick start it. You don't need stinking electric start (although I really like having it ;) )
I went ahead and put the battery back on charger at 12amp. For about 3 hours. Will see what the outcome is lol.
Lol I kick started it like 1000 times with no luck! Lol I feel like I got a 3 hour workout!
You want 12V not 12amps. Dont know if you just typo'd or what but...
Try and start it with the battery charger hooked to the battery (on the 12V setting)
Okay awesome! Thanks for the help guys!
Also, I went ahead And bought a rectifier. At raidio shack is this the right one?
Should work fine but make sure you splice the wires correctly. Positive wire to positive pole, negative to opposite pole and the other 2 doesn't matter which pole.
Awesome so I came back from work and tired the battery out! It turns over yes! But does not start probably because I don't have a gas tank on it. Lol
I'm going.yo try and clean the carbs!
You were trying to start it without fuel?
That won't work. ???
Where is this battery from by the way? Is it new? Was it initially charged properly? Is it full? If you don't have a way to check the voltage at the battery, and it's not new it could be junk for all you know. Changing rectifiers and messing with wiring is futile if you don't have a working battery.
Also, did you set the points and check for spark yet? If you don't have a manual, get one. There are links to free downloads somewhere on this forum.
