Brake Bleeding 101
Ease
83 XJ650RK, 77 TS-250
OK, so I finally got the braided lines, and have 'em installed on the bike with the R6 master cylinder (2 seperate lines from the MC)... and I have bled the new fluid to where it squirts - kind of, more like "flows" - out of the bleeders (one side at a time of course), but I can't get the things to firm up. Feels like I've pumped the lever 1,000,000 times. And I'm doing it with the fluid topped up and the cap on. No Leaks anywhere.
I've never bled brakes on a bike before... but I don't see how I'm missing something here... ANyone see what I'm doing wrong?
hey Evan,
Are you using Speed Bleeders on your brake calipers?
locO leoN said:
hey Evan,
No I'm not...
Mechanic at a local shop tild me they were a waste of money...
Have you used em?
Try this: fill the MC and tighten the cover. Loosen the bleed valve, pump the ever and hold, tighten the bleed valve, release lever. Repeat until you don't see any more bubbles in your clear vinyl bleed line.
Clear vinly bleed line hey... and here I was letting it pour all over the caliper.
I have to tear apart my beer-bong for the tube!
haha
Thanks, I'll try the tube to see if there are any more bubbles in there.
The easiest way to do it:
Get one of those large 60cc plastic syringes.
Fill it with brake fluid. Make sure the master cylinder is just about empty.
Attach a piece of tubing to the syringe and to the bleeder screw. Open the bleeder screw, and
slowly push down the plunger. It will push the brake fluid all the way through the system and fill up the master cylinder. Be careful that you don't push too much fluid into the master cylinder or it will overflow.
I do all my bikes like this and never have a problem.
You want a clear tube running into a glass jar with brake fluid in it. The end of the tube should be submersed. You want to avoid sucking any air back into the system.
Speed Bleeders (which I have but haven't put on yet) have little spring loaded valves in them. Brake fluid under pressure can escape, but the moment pressure is relieved, the valves shut preventing any dirty fluid/air from getting back up into the system.
Also critical to keep the master cylinder well filled to prevent it from sucking any air into the system while pulling the brake lever.
The reverse-bleed method described is also good.
You don't want brake fluid spilling all over the place though - it is about the best paint stripper in the entire world.
I'll have to try this next time I own a bike with disc brakes.
I disagree with your mechanic... I use Speed Bleeders on all my bikes and love them... They have never failed me and you can flush(never mind bleed) your system with clean fluid in under 10 minutes... and that's multiple calipers.
I'd be willing to bet I could do all 3 bikes, 4 calipers in total in under 15 minutes. That includes removing the tank from the BMW to get to the frame mounted master cylinder.
+1 on this one Ease...
I have Speed Bleeders on all my bikes and I can flush/bleed my brake calipers, (back and fronts), in less than 5 mins..
I know some old school mechanics dont like them cuz they prefer loosening and tightening the bleeder valve manually. Plus mechanics can charge big bucks to do the brakes... They can't charge money for a job that everyone can do themselves...
Personally I prefer boiling water in a microwave, than waiting for it to boil in the stove.....
Plus SpeedBleeders are Stainless Steel and wont rust or sieze in the caliper...Just yesterday I snapped another siezed OEM bleeder valve from a brake caliper that I was rebuilding!!!...Now I have to get it tapped..
sold the bike with speed bleeders,,,should have kept them!! they are good. one of the biggest headaches sometimes is having air trapped in the MC,snap the brake lever,,many times,then tie off the lever and wait a few hrs
Thanks for all the great advice guys!
Turns out it was all my fault afterall... I did 2 things:
1. Cracked the banjo bolt very slightly a couple of times while holding pressure in the line, and;
2. Squeezed the lever in real slowly... I had been pumping like a madman before... and apparently making more air bubbles than i was getting out... Which I'm putting my bets on as being the problem.
I'll think about speed bleeders if I ever need to rebuild / replace again.
