Where did you get your cable I am going the other direction so I need a 4 foot long cable but I haven't been able to find one and nobody locally has the ends to make my own I am leaning towards a clutch cable from a cb750 as I have one laying aroundBoxer Metal said:I have done this conversion on a BMW and the one thing I learned was the cable holder at the lever should be as close to swingarm pivot as possible to limit the lever from moving as swingarm goes up and down.
Here is the rear bracket.
Renegade said:Does anyone know if there is a kit or something to convert my cb750 from the rod to a cable like this or would i have to fab it all up myself
I found a front brake cable from a cm250 with a front drum brake. But how did you make your mountsBoxer Metal said:I have done this conversion on a BMW and the one thing I learned was the cable holder at the lever should be as close to swingarm pivot as possible to limit the lever from moving as swingarm goes up and down.
he did his wrong so you might not want to copy it exactlyMantree said:I found a front brake cable from a cm250 with a front drum brake. But how did you make your mounts
Sent from my SM-G900V using Tapatalk
I'm not actually doing rear sets I am building forward controllsxb33bsa said:he did his wrong so you might not want to copy it exactly
excellent so you need a method to hold the housiong secure at both endsMantree said:I'm not actually doing rear sets I am building forward controlls
And I am using a cm250 front brake cable my hole is to use a cable that I can get t any honda dealership so if I need a replacment I can just go pick it up
deviant said:Seems like that cable is going to wear out quickly.
