Brake caliper question....
cierrecart
My question is specific to my RD350, but I'm hoping most disc setups are similar enough that you guys might have some insight.
I just rebuilt my front caliper with new seals and new pads. Finally got it all bled and I have awesome lever action and they grab like a mofo with zero drag. Then I started wondering if I put them in the right way. I have the bottom (flat side) of the piston pushing against the pads, with the open end facing into the caliper.
Any idea if this is okay? Like I said, everything is working great, but maybe I'm not thinking of some problem that could arise from this setup. I would just switch them, but I need a compressor to get the pistons out, and since I have to go to a buddies house to use one, it's kind of a PITA.
Thanks!
It's in backwards.
It will work OK but is heavier than needed due to extra fluid in the hollow section
PJ
